-   -   Removing Registration Stickers (https://www.offshoreonly.com/forums/general-q/132174-removing-registration-stickers.html)
J.B. Marshall 06-07-2006 04:10 PM
What is the best way to remove the registration stickers from the hull without scarring it up? Is there a solvent to be used?
Cord 06-07-2006 05:14 PM
Re: Removing Registration Stickers
There is a wheel which can be mounted in a drill to rub the stickers off. This is a link to the first one I found: http://www.signwarehouse.com/TT-VR-p-HT-STPRPL.html
3m adhesive remover in the red and white can will take off the adhesive. It does not damage the gel. It's also one of the few products that will remove 5200.
t500hps 06-07-2006 06:23 PM
I've used heat gun and a plastic scrapper and the wheel. Both work fine. Heat gun method will require solvent to remove flue
Olds Eddie 06-07-2006 07:04 PM
Since some idiot bureaucrat in NC decided to use paper stickers it's much easier. Just run your boat in salt water for a week and it will remove itself!
lukiepal 06-07-2006 07:21 PM
WD-40 and a blade
US1 Fountain 06-07-2006 08:22 PM
Your wifes hair dryer to get the sticker off, then GOOF OFF to get the glue off. I've used acetone with just a good results for the glue.
J.B. Marshall 06-08-2006 06:13 AM
Thanks for the help...
JB
Baddogg 06-08-2006 06:20 AM
The Wheel That Cord Is Talking About Works Better Than Anything You Will Ever Find!
Iggy 06-08-2006 11:25 AM
The stickers that the Florida DMV uses are easy to remove. I get a finger nail under a corner and off it comes. No muss, no fuss, no residue.
To remove the glue residue I found that Goof Off is the best product.
BY U BOY 06-08-2006 11:35 AM
Lighter Fluid
