Flush Fitting for Merc 502 Mag EFI
Need advise!
Have a Baja 272 with a Merc 502 Mag EFI which will be slipped aboard a HydroHoist. Since I cannot get to the Bravo-1 outdrive water intake to use a freshwater adaptor, is there a device, fitting or connector which can be installed inside the engine compartment to simply connect a water hose to flush the engine with? |
Re: Flush Fitting for Merc 502 Mag EFI
yes there is something. Do a search using the following and read up. There is a lot of really great info on here about that.
John S. :D Do-it-yourself flush kit installs? http://www.offshoreonly.com/forums/s...h+kit+installs |
Pwrbt33
Thanks for the link! |
| All times are GMT -5. The time now is 11:13 AM. |
