-   -   575 Blower Question (https://www.offshoreonly.com/forums/general-q/132696-575-blower-question.html)
Shah Mat 06-14-2006 05:38 AM
575 Blower Question
I have a buddy with twin 575's and one of them had a rear bearing failure last year. He replaced them with blowers from The Blower Shop. He doesn't run WOT much but has noticed a decrese in speed. Boat has run the best of 79mph but yesterday it would only run 75 @ 5200. All gauges looked good. Boost was steady @ 5 psi. No other changes have been made since the blower change.
LAKESIDE RESTORATIONS 06-14-2006 11:33 PM
Re: 575 Blower Question
Was there a drastic change in ambient air temp & humidity? How many hrs on the new blowers?? Is the fuel load & boat weight / persons still about the same as the last faster run?? Just curious.. Jamie / lakeside
customryder 06-15-2006 08:39 AM
air temp
Steve Zuckerman 06-15-2006 08:48 AM
Shah Mat,
I'm off 3/4 MPH from my spring #s too. 95 degrees and 90% humidity will do that...........
A question about those blowers. Do they have teflon tipped rotors, or are they machine fitted like the Weiand? If they are tefloned, the teflon strips may need replacement.
When I had TBS rebuild my Merc/Weiand 256, they asked me if I want the rotors tefloned (they aren't from the factory). It would have given me another lb. or 2 of boost at the same rpm, but I declined, because of this annual maintenance.
I have run both styles, and I prefer non tefloned, even though it is slightly less efficient, because you end the season with the boost you started with, unless you FU the blower, of course :rolleyes: :eek: ...................
Steve
JaayTeee 06-15-2006 01:49 PM
Mine have been all over the place
this year too.
I'm with Customryder on this one.
