-   -   Bravo 3 won't shift (https://www.offshoreonly.com/forums/general-q/132731-bravo-3-wont-shift.html)
Mkeller 06-14-2006 01:18 PM
Bravo 3 won't shift
This falls under stupidest thing I've done boating without ever leaving the lift. Started the boat last saturday to take it out to dinner. Engine was idling about 3500 rpms in neutral. Thinking there might be a sticking throttle cable I moved the throttle forward without disengaging the shifter. Realized my mistake and quickly turned the engine off. Now it won't shift back into neutral. I Can see the cables moving on the engine when I move it but the shifter will not move into neutral. I use Amsoil marine gearl lube.
From what I can tell no gears are actually engaged. The props can be turned in either direction without resistance. All cables are in place. I pulled the rear cover and nothing seems to be broken. Pulled the drain plug and no fragments.
My mechanic can't get to me until next week at the earliest. My fear is blown drive.
Anyone have any thoughts?
GOODT 06-14-2006 01:42 PM
Re: Bravo 3 won't shift
bravos dont like to shift when not running, best way to get it in neutral is to crank motor with coil lead off and shift while cranking you will need to jump the slave solenoid because the neutral safety wont let you crank it with the key
if you want more details of how to do this give me a call And id be more then happy to go though it with you......
Mr Gadgets 06-15-2006 06:32 AM
Mkeller,
The input shaft to the drive needs to be turning when you shift a bravo.. Like Joe said, you will have to bypass the neutral safety switch. You can pull the kill cord if you have one to kill the ignition. If you pull the coil wire, it should be put to ground, so the spark has somewhere to go. I know from experience that a MDS box will fry a coil in a heart beat..
If it still wont go into neutral, you may have welded the cone clutch to a gear. But as you spin the motor over, if it doesnt go into neutral easily. then tug on the control.. to see if you can break it loose. Not too hard, it could damage the cable..
Hope this helps
Dick
Mkeller 06-15-2006 10:54 AM
Thanks for the feedback. I was able to get my mechanic to show up last night. He removed the shift cable at the engine, put the control box in neutral and started it up and reconnected the shift cable. Wouldn't shift. He played around with it awile and is convinced the drive will have to come out to free it up. Guess I'm looking at a rebuild on the upper.
Big Block Billy 06-16-2006 12:56 AM
If you can haul boat easily , do so , drain drive and remove rear cover(3 bolts) and see what's going on. Maybe damage or breakage to Iron shift arm has occured. You can see what's happening and look at gears and all from this standpoint... BBB
Big Block Billy 06-16-2006 01:01 AM
Originally Posted by Mr Gadgets
Mkeller,
Hope this helps
Dick
YES it" s true bravo drives are not meant to be shifted without motor running, they have syncros with timing marks that act similarly as syncro rings in in a manual automotive transmission... BBB
MOP 06-16-2006 05:48 AM
I had one that refused to come out just cranking, I tied it tight to the dock fired it off let it run a minute it shifted out and is still just fine. By your discription I doubt if you welded the cone.
Phil
Mr Gadgets 06-16-2006 06:23 AM
MOP.. did you shift it into gear at 3500 rpm??
Mkeller, If you feel up to it.. You can remove the top and back caps, remove the shift fork retaining bolts, pull the shift shaft out and then shift the clutch in the opposite direction that it is in now. That will tell u if the cone has stuck in a gear. I dont really see how the linkage could break from moving it into gear. I do see the oil on the cone and gear surfaces being forced out at such a high rate that the cone could wedge itself into the gear and stick there. That is what I meant by welding the cone to the gear. Years ago I had a Merc Certifed mechanic tell me that when this occurs, then you put one foot on the dash and yank as hard as you could.. Well I never bought that senario, but if the cone is stuck in a gear, you may be able to pry it out without taking the drive completely down. If you want further info on how i would do it.. give me a call...
Dick
616-403-1006... cell
MOP 06-16-2006 05:20 PM
I would give the run thing a try first not saying it will work in this case, if a no go then take it apart and lap in a new cone.
GOODT 06-16-2006 08:05 PM
or it could be as simple as a broken shift cable.......... had two today on two differnt boats neither would shift out of gear one the outer housing where it went through the bell housing was broken the other the outershield was melted due to engine over heat
Big Block Billy 06-17-2006 09:57 AM
I had worked on a boat 5 years ago that the customer had hit something and one of the drives would not go into gear.
I ended up taking the rear cover off and noticed the iron lever that moves the shift shaft, was broken. I was two hours from home, and far from a Merc dealer, and it was a Sunday. I welded it and put it back in and amazingly the drive worked fine. There was a burr on the shift fork that I filed off too. So don't try to force drive too hard, you could easily break the shifter on your dash, (it's parts are diecast)
Instead take rear cover off as well as top cover, and take apart shift parts and examine cones, gears, as well as shift fork. The shift fork easily unbolts from the shift shaft with an allen wrench. The shift shaft comes out easily by screwing a 1/4" - 28 fine threaded bolt into it and simply extracting it. After shaft is removed, fork can be examined as well as all else in the upper. Hope this helps, BBB
Mkeller 06-19-2006 08:15 AM
All,
This site is awesom. Tanks for the feedback. I did pull the rear cover and and could see nothing broken. Tried some gentle pressure on the clutch and couldn't move it. Rather than risk breaking something, or falling in the canal, I am having the boat pulled this afternooon. Even if I freed it up, I have a bimini trip in early July and don't want to find out 30 miles from land that a problem still exists. I will post the problem and fix once it's happened. With luck it will free right up and all I will get is a bill for a couple of hours of labor and a big lecture from my mechanic for not running the merc green stuff in the drive.
Mike
Mkeller 06-27-2006 08:44 AM
The drive was pulled Friday. I twisted the drive shaft and broke one of the vertical shafts. Gears and clutch appear ok. I will be retaining the broken parts as paper weights and a reminder of my stupidity. (All this due to a $1 brass plug that corroded and sprayed salt water on the engine causing the carb secondaries to stick open.) What would boating be without a major repair every other year or so? On the plus side, I learned the boat will readily plane on 1 engine with the non running drive up without any signs of overheating. At any rate, I will have it back this week in plenty of time to get ready for my Bimini trip July 7.
