-   -   steering trouble ? (https://www.offshoreonly.com/forums/general-q/133551-steering-trouble.html)
johnny b good 06-23-2006 08:41 PM
steering trouble ?
Hi everyone. I bought a 1997 38 powerqwest for a good price in January,boat engines and drives checked out good with survey. Never water tested. First time out bought ran great but wants to pull to port on plane. If you let go of the steering wheel she will start turning to port fairly fast.Whats up? stock 502 mags b-1 drives power steering internal,tie-bar,240 hrs. thanks for any help.
ALL IN 06-24-2006 08:55 AM
Re: steering trouble ?
i would check the tabs are in the same location not using the indicators if one is off it will pull also measure your outdrives at front and back should be equal i had one that was out and it took speed and pulled and was only off a little
DORaymond 06-24-2006 09:38 AM
Also make sure that the zinc skegs above and behind the props are straight (parallel with the centerline of the hull).
