Stainless marine exhaust gaskets ?????
Couple of questions
What type of gaskets do I use for stainless marine manifold to head? What type for risers? Also Gen VI motor mount for 29scarab. What type bolts to block? Had someone on the board show me the one to use on the L brackets in the engine bay. Think it was that one with the stud and 2 bolt holes on the outside. Thanks, :D |
Re: Stainless marine exhaust gaskets ?????
go to your local spped shop and match up the correct felpro gasket set. i run the gen 3's and they take a larger the normal gasket with the square hole. if you have the smaller manifolds i think the use stock dimension square hole type.
Yup Yup Dont Waste Your Money Ordering Them You Will Get Boned At The Boat Store... Local Speed Shop..........
Make Friends With Those Guys You Will Be Seeing Them A Lot.......lol... |
My stainless marine hi tq 3's use a mr gskt 5913 (large port,sq port),they are pretty durable and run 20$ a set,yours may be the mr gskt 5910's. Spend the extra 10$ and get the "ultra-seals",they don't burn out as easy. If you measure your exhaust ports and pm me I can check if they are the 5913's or the 10's as I keep a extra set of 5913's on the shelf and can measure them,Smitty
| All times are GMT -5. The time now is 06:50 AM. |
