Help
After Putting A Roller Cam In My Mark Iv Block And Testing. I Reset My Rocker Arms To Zero Lash And Half A Turn And Locked Them In By Turning The Allen Screw Till It Would Not Turn Anymore Then I Turned The Nut And Allen Screw Another .25 Turn. On A Water Test She Ran Fine For Twenty Minutes Then I Lost Power. I Pulled The Valve Covers To Find Two Rocker Arms Came Loose. Is There A Better Way To Lock The Roller Rockers In Or Is Something Else Wrong That Is Causing This. Thanks In Advance Patrick
Re: Help
If it happens again, try some blue locktite, it should not be necessary though. |
Re: Help
That Is Basically What I Did. All The Others Are Tight And No Push Rods Are Bent. This Was Recommended By Marine Power Who Is Where All The Cam,heads And Exhaust Came From. Wobble Will You Be Around Clear Lake For The 4th. I Was Thinking If T We Could Get Some Members To Raft Up For The Fireworks.
Re: Help
Do lash like normal, 1/2 turn on nut is fine. Hold nut with open end very tightly and use high quality allen wrench to lock down the allen screw with some force.
That's it. Don't move adj nut once done, you'll probably loosen the allen screw. ================ The aleen screw locks it down by pushing against the stop of the stud and creating inteference by the allen screw's threads and the threads of the nut. In other words, Since the stud and nut will be stationary when setting the screw, you'll cause inteference by turning it down and creating holding pressure to the other two items. Gosh, tough to type words sometimes. :p |
Re: Help
My post above is backwards. my bad. Thinking about something else :eek: . The procedure that SB wrote is correct. Nut stays still, allen is tight-end.
Re: Help
Will be on the river Sat and Sunday for sure. |
Re: Help
Originally Posted by Wobble
I might make the run, I see it's going to be a half moon. It depends on how my 4 year old is behaving :D Cant go to see the fireworks without the whole family.
Re: Help
Re: Help
I AM TRYING TO GET THIS SH#T DONE FRIDAY AND BACK ON THE WATER SUNDAY. GOOD NEWS IS I DID GAIN 6 MPH WITH THE MODS. I HAVE NOT PUT MY HYDROMOTIVE ON SO ONCE I CAN RUN A LITTLE LONGER THAN 20 MINS I HOPE TO SEE 68 TO 70. I SAW 65 YESTERDAY WITH NO TRIM 60 GALLONS OF FUEL AND 3 200LBS GUYS.
3 200LBS GUYS.
Re: Help
congrats on the speed increase
Sausage party :eek: |
Re: Help
:evilb: :drink:
Re: Help
I PROMISED SOME INSTALLERS THAT WORK FOR ME A RIDE FOR SOME WORK THEY DID WHEN I GOT DONE. I NEVER SAID IT WOULD BE A ROUND TRIP. :eek:
Re: Help
Originally Posted by fund razor
Anybody remember my scientific formula for checking weight effect on speed by tossing friends off the boat one at a time? :D :D
Re: Help
I DO KNOW THE EFFECT 8 WELL PROPORTIONED LADIES DO TO MY SPEED :evilb: :D
| All times are GMT -5. The time now is 11:23 PM. |
