Old Bravo lower W/ new Bravo upper?
Can I bolt an older (pre 1990) Bravo lower to a newer (post 1995) Bravo upper? The only real difference I can see is an oil hole in the newer drive. Thing is, some of the IMCO lowers have this oil hole blocked.
So, can I run an older lower with a newer upper? Can I also do this visa-versa? (newer lower W/older upper)? Thanks, Gordo |
Re: Old Bravo lower W/ new Bravo upper?
Also,
I have seen a newer "replacement" lower that had the "boss" for this oil hole, but the hole was not there. Can I drill out this oil hole to use with newer upper? Do I even need to? |
You can put an newer lower on an older upper. Simply put a plug in the extra oil in the newer lower. I've run one that way for 2 years.
What does that hole connecting the upper to the lower do,allow oil to drain back,let oil from churning in lower pump to the top or is it a vent? I have a nice early upper I just could have sold a few days ago to a friend :( but didn't think it would work,at least I know now though,Smitty
Now, is it possible to run a newer upper with older, (non oiler) lower if I simply plug the upper hole? |
1 Attachment(s)
no you can not run newer with older its an oil hole and provides improved oil circulation on the drive which inturn lets them run cooler I wouldnt recomend "plugging it" to anyone bravos need all the help that they can get
That is what I was told by the company that I bought my new style lowers from. They are known for doing performance upgrades on Bravos. The lowers I bought had been replaced with some shorties.
GOODT tell me if I was told wrong. And how can it be fixed? |
| All times are GMT -5. The time now is 07:50 PM. |
