-   -   Push or pull? (https://www.offshoreonly.com/forums/general-q/134233-push-pull.html)
ghittner 07-02-2006 06:33 PM
Push or pull?
Push or pull fuel through the stock merc canister filter? 172 gpm mechanical pump. Running dual 750's w/ a blower. I've always heard you should push through. Is that correct? Thanks.
GOODT 07-02-2006 06:35 PM
Re: Push or pull?
normal set up is pull
MOP 07-02-2006 06:49 PM
Re: Push or pull?
Most all setups have the filter before the pump be it manual or electric, makes a lot of sense would rather have the engine die from an air leak or have a bilge full of fuel?????
ghittner 07-03-2006 12:16 AM
Re: Push or pull?
I've always been told that if you can push in a performance application it is better flow???
Iggy 07-03-2006 05:30 AM
Re: Push or pull?
If you're running a mechanical pump, I'd pull it through.
Since most electric pumps have limited suction capability, that's why they have to mounted as close to the tank as possible, then the filter has to be pressurized.
