-   -   mefi 3 ecm (https://www.offshoreonly.com/forums/general-q/134276-mefi-3-ecm.html)
wildcoby 07-03-2006 11:56 AM
mefi 3 ecm
In march i repowered my 1999 ebbtide from a 5.0L tbi to a 5.7l tbi.I purchased the engine from michigan motorz and they sent the ecm to marine power in louisanna to have reprogramed .the problem was that one of the two dropped the ball, because marine power can only reprogram to gm specs and the computer was programed to mercruiser specs.I was told they both do it differnet. It would not do anything when hooked up.So michigan motorz sent it to someone else that said they could do it.it now has 5 volt refence signals ,but no signal to the coil or injectors.My question is it really possible to reprogram the mefi 3 to mercruiser specs and if so does anyone know someone who can.
wildcoby
Outdrive1 07-03-2006 12:06 PM
Re: mefi 3 ecm
I know AZ Speed and Marine can do it. I hate to pimp them after all the times they f-ed up my boat but I'm sure they are condifent enough to put a stock Merc. program back in that ecu.
GOODT 07-03-2006 12:14 PM
Re: mefi 3 ecm
I also have had Arizona speed reprogram ecms for me
Dock Holiday 07-03-2006 12:55 PM
Re: mefi 3 ecm
Precision Marine
Kenner, LA
Mark Boos
Tyler Crocket
I have used both and both know their stuff and will give you an honest answer and good service.
MnHowardCat 07-03-2006 10:42 PM
Re: mefi 3 ecm
Tyler Crocket did mine and he is in Michigan
Don
LAXBAJA 07-03-2006 11:38 PM
Re: mefi 3 ecm
Precision Marine did mine give them a call 504-469-7463
Good luck
