Bravo I Drive Won't Trim
Needs some help sorting out why my bravo drive won't lower on my velocity. The trailer button will raise it. Will not lower. Will bad trim limit switches cause this. Trim gage is giving accurate reading. Any one have a schematic handy or can me a clue to isolating this issue? Is there any way to hot wire past the trim limit switches?
Thanks! Vmax |
Re: Bravo I Drive Won't Trim
I had same thing happen on mine, it was a coroded terminal on circut breaker.
What circuit breaker and where was yours located? I repalced a fuse on trim pump bracket with no joy. Fuse crumbled when I removed it. I replaced it and it did not solve my problem. Is there a relay could be bad? If so where? How do I test the relay. Since trailer switch works the pum must be getting power.Removed dash rocker switch. I can not hear any relay click when rocker makes down contact. Completing circuit by toucking rocker switch wires with jumper has no effect. Makes me believe rocker is Okay. And yes I have been testing ignition switch on.
If trim limit switch is bad won't drive still trim down anyway? Any help would be appreciated. Vmax |
Mine was on 99 27 fountain the breaker was under rear seat, I would trace and ck conections.
1 Attachment(s)
Originally Posted by Vmax
If trim limit switch is bad won't drive still trim down anyway? Any help would be appreciated. Vmax YES, it will still go down it only breaks the up circut....... do you have power to the soliniods ? do you hear them click ? bellow is a diagram for checking the solinoids |
Bad solenoid.
I hard wired trim limit switch out of the circuit. Rocker switch in up tried to lift the drive, heard up solenoid click. Wasn't functioning since trim limit was overiding. Tapping down solenoid with switch powerd to down no success. Jumpered across green wire to positive got drive to lower. Quite conviced the solenoid is the culprit. At this point. Waiting for rain to stop to troubleshoot further. Will check continuity on rocker switch for down position. Know currently up circuit works. Only saw three wires connecting to Rocker. Two reds to center post and purple white wire to bottom. Should there be another wire connected to rocker may have came loose under side console. Can't read the schematic jpeg.
email me Ill send it to you
Issue was wire connection for down position at rocker switch. Recrimped and good to go. Thanks for the help.
Vmax |
| All times are GMT -5. The time now is 03:05 AM. |
