Trim sender switch
Forgive my stupidity but I recently had my engine pulled for some transom work and everything is back in place but the trim sender wire. The trim works fine of course but my gauge is dead. This is an 87 Formula with a new engine and it worked fine before we pulled it. The stupid part is I can't remember where this wire connects to! It's a single circle terminal that attaches to a small screw but I can't locate this. I know its on the starboard side but where? Please help refresh my memory, or lack of! :(
Re: Trim sender switch
you did not say what motor you have but in most cases the connection for it should be by the red 50 amp breaker
Sorry, its a new 350 magnum.
1 Attachment(s)
Here you go hope this helps
Thanks everyone I found my brain with your help. The wire was tucked under the mercathode. Anyway I'm good to go now. Thanks again! :drink: :drink:
cool, glad to hear
a Brain is a terrible thing to loose |
GOODT to the rescue again !
