-   -   Vapor Lock Issue (https://www.offshoreonly.com/forums/general-q/134589-vapor-lock-issue.html)
bblythe 07-07-2006 11:22 AM
Vapor Lock Issue
i have twin 502s 1999 which seems to have vapor lock problems if i run boat hard and stop let set 1/2 hr sometime very hard to start bleed fuel rail then starts ok
Von Bongo 07-08-2006 12:36 AM
Re: Vapor Lock Issue
Common problem with the 454/502 MPI mags. Do a search merc had a bulletin out about it. I beleve it was let it idle for x minutes before shutting it down and leave the hatch open to let air in to cool things down.
bblythe 07-08-2006 12:48 AM
thanks for helping me
Von Bongo 07-08-2006 01:02 AM
No problem us Iowa people have to stick together.
Heres the bulletin
http://www.outdrives.com/bulletin/se...9/mcsb997x.pdf
greencard 07-08-2006 08:46 AM
Merc has a one way valve "update" to keep hot water from flowing out of block to fuel cooler. I have seen this fix work, search merc website. Valve is around 90.00,good luck.
j_cizzo 07-08-2006 11:35 AM
does it have a fuel return from the pressure regulator? if it doesn't, maybe try putting one on, i would think that by constantly having the fuel circulating, it'll never be given the chance to absorb the heat and vaporize, therefor you'll avoid your vapor-lock... if you have efi, for this system to work tho, you'll probably have to move the regulator to the OTHER fuel rail, basically the fuel flows in one rail, crosses over to the other rail, hits the regulator which pressurizes the system, and then bleeds off the excess fuel back to the return.... it's actually a very simple and efficient setup...
if you're carbed, then don't worry, just throw a regulator on AT THE CARB (meaning don't have it screwed into the side of the engine compartment with a long fuel line running to the engine) a fuel pressure regulator SHOULD ALWAYS be as close to the fuel bowls as possible, then just run a return line back to the tank.... should work like a charm!
