Spacer kit for Stainless Marine manifolds
Has anyone seen or used a spacer kit for stainless marine manifolds that go between the manifold and stainless riser?
Pics please if you have any. |
Re: Spacer kit for Stainless Marine manifolds
Yes. When I bought the system with 3" risers I needed 4" so the made a 1" spacer for between the manifold and the stainless riser. Give them a call they should be able to make what you need. If I remember correctly it held the system up a bit because it took longer to make than they thought.
[email protected] |
| All times are GMT -5. The time now is 02:51 PM. |
