-   -   454 Mag MPI (https://www.offshoreonly.com/forums/general-q/134755-454-mag-mpi.html)
MC-BOYS 07-09-2006 09:56 PM
454 Mag MPI
I have a 454 Mag MPI; bought it used with 68 hours. I put approximately 20 hours on engine. Ever since the first time, engine has had difficulty starting, rough ideling, and surging. I thought it was just bad gas, plugs and wires, but after fresh fuel and new plugs and wires, still having above problems. This weekend, I went to start the boat, and the audio warning system went off even before starting the engine, and the engine would not start, and when it started was surging, ideling rough and stalled. There was no problem with the oil pressure, temp or drive oil. I thought it could possibly be the computer, but without diagnostic tool, not sure. Other possibility could be the fuel injectors. Does anyone have suggestions or thoughts. Engine is getting serviced this week.
GOODT 07-09-2006 10:03 PM
Re: 454 Mag MPI
check the VST if equipped you didnt state a year..... rough Idel and surgging could be one of many things on a mpi from iac to tps but if equiped with a VST system and without looking at sensor values Id start there
LAKESIDE RESTORATIONS 07-10-2006 08:26 AM
Re: 454 Mag MPI
Joe is right depending on the year. You may also have a bad IAC motor or a vaccum leak.. Jamie / Lakeside
MC-BOYS 07-10-2006 02:11 PM
Re: 454 Mag MPI
The engine is a 1999. We had checked for vaccum leaks and there does not appear to be any. What is VST? Thanks for the input
LAKESIDE RESTORATIONS 07-10-2006 02:23 PM
Re: 454 Mag MPI
VST system it an efi hybrid. It has a fuel resivoir like almost like a carb & 1 low psi & 1 high psi pump. the 99 I donot belive has this. I believe it was the earlier ones. I would think more IAC or TPS may need checking or even a map/baro sensor... Jamie / Lakeside :)
GOODT 07-10-2006 02:32 PM
Re: 454 Mag MPI
1 Attachment(s)
here is a flow chart of what to check so your not wasting alot of time
I think donz133 my be right about the iac with out a scan tool its a shot in the dark and will take alot longer but follow the chart and it will take you in the right direction
there is more charts to follow when you get done here or have other symtoms
and yes they stopped using the vst in 1998
MC-BOYS 07-10-2006 03:30 PM
Re: 454 Mag MPI
Thanks guys! Appreciate the input. I have the service manual for the 454 Mag MPI. We are going through the flow charts for trouble shooting the problem. I let you know what we find.
MC-BOYS 07-11-2006 02:15 PM
Re: 454 Mag MPI
Diagnostic test showed that the intake air temperature sensor is faulty. We ordered a new sensor. Hopefully, that should resolve the symptoms. Thanks for your help.
