Pressure relief valve failure
I installed a water pressure relief valve from Teague for the 05 season. It worked very well keeping my pressure below 25psi even at WOT. After 40hrs of total run time I started losing pressure, and could barely keep 10psi even at 80mph. After checking every hose and fitting for debris, I found the valve was wide open and letting free exchange of water at all times.
I called Teague and Adrian in parts said they normally only warranty these a year, and I had it for 20 months. Since it was an $80 part that I had to replace I was annoyed, so he offered to have the boss call me. I’m glad to report a short time latter, Bob Teague called me, and a new valve is on the way. In an industry with so many bad raps, it's nice to see Teague stand behind their products. Thanks, Bob Dave |
Re: Pressure relief valve failure
Which ones are they?
At least that worked out better than your 1 year old GGB's that split in half. :mad: I keep checking mine to see if there are any cracks in the welds. So far, so good. However, I am sure that when and if they do crack , they will just fall off as did yours.
They are the ½” intercooler relief valves.
Vinny, Fionn at Oneill Offshore has my GGB’s now. He is going to build another for me, and reinforce the problem areas. |
That is the exact reason I am now avoiding the relief valve setup, fear of it sticking open. My WP has been hitting 50psi this yr, so I have been limiting my rpms to 3500. I'm in the process of modifying an old style Merc T-stat housing with the 4 hose setup that incorporates the bypass system . And no moving parts!
That's good to hear of Teague honoring your valve. |
Vinny, Fionn at Oneill Offshore has my GGB’s now. He is going to build another for me, and reinforce the problem areas. Dave, Yes, I forgot you had told me they were being repaired. Hopefully, they will hold together this time. |
| All times are GMT -5. The time now is 12:01 PM. |
