-   -   Sucking sound from 500 EFI ??? (https://www.offshoreonly.com/forums/general-q/134819-sucking-sound-500-efi.html)
kennyo 10-19-2007 07:57 AM
Dock, did you wax the intake while you had the plenum off?
Dock Holiday 10-19-2007 01:09 PM
Well I'm glad to see this thread still here and still helping folks.
Actually if you have a reall good hydraulic shop in the area you can go and buy the o-rings for about .35 cents each. That is what I did once I found the right size and I keep a spare set in my shop.
Like Jeff said it is easy, you really cannot mess up and all they are is o-rings and not gaskets. Personally I would replace them all if it were me and I had it apart.
Good luck
BYFS 04-25-2016 09:58 PM
Great post, I've learned a lot since I'm having the same issue on my 500efi, I'm also having surge issues, sounds like a 1071, can't imagine these issues are related,or are they?
dereknkathy 04-26-2016 12:04 PM
Swap the 2 IACS...Heck, swap the throttle bodies complete.
ctuck0659 04-30-2016 08:05 PM
Seems to me I had the same issue a few years ago so I'm a little fuzzy on the details, but I think I found I had low vacuum at idle & a large vacuum leak. The sucking sound may be air getting sucked past an almost completely closed IAC.
