-   -   Another Bravo Drive Trim Question (https://www.offshoreonly.com/forums/general-q/134996-another-bravo-drive-trim-question.html)
34scarab 07-12-2006 05:05 AM
My Stbd. drive is giving me problems.
The trim acts normally when on the lift, up-down OK.
However, when out on the water, under power, it won't pick the drive up.
I have replaced the trim pump with a new one and now don't know where to look.
Could it be some bad wiring and the amps it is drawing when under load are too much?
Help please.....
Lake-x 07-12-2006 08:29 AM
Re: Another Bravo Drive Trim Question
Switch the hoses around at the pump & try again.
34scarab 07-12-2006 10:58 AM
I am not sure I understand.
Is there a high pressure hose that I am missing?
The drive does go up and down, when sitting still.
It is just under load, it won't go up, but it will trim down while under power. If I trim it partially, hten get on plane, the drive holds it's position.
eyezlee 07-12-2006 11:02 AM
We're having the same problem on a Fountain. Checked voltage to the pumps and all is good. Any thing else to check out?
NJSONIC 07-12-2006 06:55 PM
Just a thought. May be one of the o-rings in your trim cylinders is damaged causing the fluid to bypass when under pressure and weight of the boat.
