-   -   7.4L cam (https://www.offshoreonly.com/forums/general-q/135042-7-4l-cam.html)
MadMat 07-12-2006 01:52 PM
7.4L cam
Can anyone confirm what the stock cam specs for a 1988 7.4L should be. My service manual states 350/352 advertised and doesn't state LSA - but this seems crazy so I'm sure it must be a misprint.
Matt
OLDRAT 07-12-2006 02:32 PM
Re: 7.4L cam
Mad,
The data I have for a 1988 7.4 (330 hp - not Mag) is:
Lift int-.461 and ex-.479 Advertised dur int-.350 and ex- .352.
Duration at .050 is 214/218 degrees, the lobe separation is
115 degrees
Merc PN 437-4734
OR
rmbuilder 07-12-2006 02:46 PM
Re: 7.4L cam
Matt
Matt,
You are correct, that is a mis-print in the manual. (Not the only one)
The correct spec are:
Merc #431-4734
GM# 3904359
278º/289º @ .006"
213º (214º)/ 217º (218º) @ .050"
.270"/.282" Lobe
.460"/.480" Valve
110º ICL
118º ECL
114º LSA
Bob
MadMat 07-12-2006 03:00 PM
Re: 7.4L cam
Thanks guys.
Pat McPherson 07-12-2006 03:37 PM
Re: 7.4L cam
I've got one I pulled out of my 1989 7.4 years ago.
If someone wants it, buy me a drink, and pay the shipping.
SB 07-13-2006 09:11 AM
Re: 7.4L cam
Matt
Sounds like one of those old Buick 455 cams. LOL !
The guys above gave you the right info. I have a little more info in my notes:
Standard Flat Tappet (oval heads)
.004” 287*, 302
.006” 278*, 289
.050” 214*, 218*
.200” 111*, 119*
Valve lift with 1.7 .460” , .480”
ICL 110 ATDC
ECL 118 BTDC
114 LSA
