Is there a gasket that goes between....
a Bravo 1 outdrive and the so called bellhousing. Putting a BRavo 1 on for the first time and want to make sure I don't miss anything. I see where the shifter cable latches in , but wanted to make sure there is not a gasket that belongs between them.
I wanted to thank JOE at KI Performance marine and the other guys on the board for helping me answer the questions I need to get my boat back together. I'm going to try to fire the engine this weekend for the first time in the boat after the boat sitting a year!! Thanks, shawn |
Re: Is there a gasket that goes between....
there's a set of o-ring type gaskets that go in there. its called a bravo one gasket kit and sells at the dealer for about 8 bucks. hope this helps good luck :drink:
Thanks 98 for the input!! :D
all that goes there are the o rings I like to put alittle gorrila snot ( 3m super weather strip adhesive ) on them to be sure they dont move while installing the drive
GOODT,
I'm back to working on the boat again tonight. I put the outdrive on the other night and can't remember if I saw them or not, so I'm pulling the outdrive again to make sure everything is in the right spot!! Thanks guys!!! :D |
| All times are GMT -5. The time now is 01:07 PM. |
