-   -   Cam Specs needed (https://www.offshoreonly.com/forums/general-q/135166-cam-specs-needed.html)
nordic95 07-13-2006 05:47 PM
Cam Specs needed
Does anyone have the specs for the O.E. cam used in a 1991 502 mag 415 HP Merc???
Thanks Nordic95
SB 07-13-2006 08:26 PM
Re: Cam Specs needed
Why yes I do:
Mag BBC 454/502 Flat Tappet (rect heads)
.004” 296*, 296*
.006” 286*, 286*
.050” 224*, 224*
.200” 130*, 130*
Valve lift with 1.7 .510”, .510”
LSA 115.5
Part#431-9830
ICL 114 ATDC
ECL 117 BTDC
Part#431-850478 (same as above but ground with 5 degrees advance)
ICL 109 ATDC
ECL 122 BTDC
SB 07-13-2006 08:29 PM
I forgot to add, the 90-92 502 Mag used #431-9830. See above. This is according to BAM's website look up tables.
nordic95 07-13-2006 09:44 PM
Thanks SB
Nordic95
