-   -   Impeller location 7.4 mpi (https://www.offshoreonly.com/forums/general-q/135204-impeller-location-7-4-mpi.html)
snake plissken 07-14-2006 02:32 AM
what does it look like and where is it loated? i just picked up my boat had a procharger installed thought i would start it up real quick just to hear it run real quick made a loud squeal so i shut it down my serpintine belt broke I whent and bought a new belt a tad larger installed it .this time i lowered the drive in a tank with water before i started it . cranked right up but no water is being sucked up nothing dripping out my exhaust like it normally does so i figure its my impeller.where the heck is it located??and how hard to replace thanks Vince
Island Hopper 07-14-2006 09:36 AM
Re: Impeller location 7.4 mpi
It is on the lower R/H side of the engine. You are looking for the seawater pump. You should have seen it when you replaced the belt. the belt also turns this pump.
GOODT 07-14-2006 10:06 AM
2 Attachment(s)
heres a pic
Wally 07-14-2006 10:28 AM
Here you go....this is for a 500EFI engine that has the fuel pump as part of the water pump....but the jist of it is all the same.... :D
http://www.offshoreonly.com/forums/s...light=impeller
snake plissken 07-14-2006 10:34 AM
Hi thanks goodt can you email me the pis im unable to view [email protected]
GOODT 07-14-2006 10:58 AM
sent
