Stroke Me!!! >
Stroke Me!!!
Stroke Me!!!
Old 07-18-2006 | 04:12 AM
cig1988's Avatar
Default Re: Stroke Me!!!
Thanks for all the great info. Sending a truck sometime today to p/u all the essentials from Callies in Ohio. We are going at least 555 cu in. If anyone has any more feedback by all means feed me away before I pull the trigger.
cig1988 is offline
Old 07-18-2006 | 07:13 AM
KAAMA's Avatar
Originally Posted by cig1988
Definetly staying with short deck. As you said with the tail pipe height, I'm not messing with the transom. Is 565 the max ci on a short deck ?
Stan
Stan, I'm no expert here, but I think if you go beyond 4.25" stroke on a short deck block it will have exessive wear problems on the cylinder bores.
Also, a 345cc head is kind of large for a 565cid engine although it will work, but as gg10 said you will leave a lot of torque on the table. However, being that you already own the heads now, you do have an option---you can send them to "JimV" and have him install some of his wedges in the ports and make the port smaller and bring back a bunch of torque and power for your cubic inches----so, you CAN make them work for you. If you have any questions you can call JimV's cell at 616-889-0928.
JimV works closely with "rmbuilder" aka Bob Madara of Marine Kinetics from N.Y. Bob's number is 585-654-8583. A word to the wise,....I would DEFINATELY call Bob BEFORE you make any final descisions on cam selection!
Have fun with your project!
KAAMA is offline
Old 07-18-2006 | 07:16 AM
cig1988's Avatar
JimV works closely with "rmbuilder" aka Bob Madara of Marine Kinetics from N.Y. I am telling you---Bob Madara THE MAN with the cam! Bob's number is 585-654-8583. A word to the wise,....I would DEFINATELY call Bob BEFORE you make any final descisions on cam selection!
Thanks Dave, will do.
cig1988 is offline
Old 07-18-2006 | 07:40 AM
KAAMA's Avatar
Oh, by the way....my name is Mark. "Dave" Wesseldyk is the owner of WESCO Racing---he's the guy who built my 565cid engines, Bob Madara supplied the hydraulic roller cams, and JimV did some port massaging on my AFR cnc ported heads and I am very pleased with how everything has turned out!
KAAMA is offline
Old 07-18-2006 | 09:40 AM
Stan,
I second Mark's recomendation on getting with Bob Madera. Great running engines don't have to have great parts, they have to be great combinations. Bob can give you invaluable information on performing combinations and parts.
cstraub is offline
Old 07-18-2006 | 10:05 AM
cig1988's Avatar
Sorry Mark, I appreciate the great info on this.
Stan
cig1988 is offline
Old 07-18-2006 | 09:08 PM
AIR TIME's Avatar
Re: Stroke Me!!!
hey the 598 was 770tq at 4500rpms and 775hp at 5500rpms motor was 16,000 dart block 345 heads .
AIR TIME is offline
Old 07-19-2006 | 04:05 AM
cig1988's Avatar
Thanks all for the fantastic info !
cig1988 is offline
Old 07-27-2006 | 02:36 AM
Out of curiosity where did you end up?
My personal feeling is that the 345's are too large for the small-ish combo and low RPM. Hard to swallow swapping them but it's easier to do it now than down the road.I'm wondering how these were decided on - If money was no object what drew you away from the 335's?
4.250 x 4.600 is an easy build for this one - 565 cubes and easily sourced components.
Hello Chris, weird palces we find ourselves huh?
Brian
scatstroker is offline
Old 07-27-2006 | 03:48 AM
cig1988's Avatar
Brian
Decided we will throw the old stuff together for now just to get a few weeks out of the season. Will do this as a winter project so there is no rush. Alot of good options and we may go tall deck.
Stan
cig1988 is offline
joker9r
09-13-2008 06:29 PM
ninetym
17
12-29-2007 07:10 AM
two-air
16
04-21-2007 04:25 PM
