-   -   Bravo1 Noise (https://www.offshoreonly.com/forums/general-q/135314-bravo1-noise.html)
mars 07-21-2006 05:55 PM
Re: Bravo1 Noise
Two things are against me, I am living in Quebec Canada and the other is that the drive serial number starts with OL and Merc don't make them anymore, they have a superceded .
Anyway if you feel that I am paying too much, I would like to hear about it.
Thank you
GOODT 07-21-2006 06:56 PM
Re: Bravo1 Noise
1 Attachment(s)
where are you getting this merc doesnt make them any more crap ????
if a part is superseded it just means that they refer you to a differnt part # 99.9 % of merc parts have super sesions
trs merc doesnt make any more
the gear set is about 900.00
gear lube 39.95
dissasemble, clean, inspect upper 300
seal kit 100.00
reassemble upper 300
what was the actual damage
if metal present you want to dissassmble cln and inspect lower add another 300.00
im on marylands eastern shore we are not cheap here but 2600 to swap out upper gears is high
this is the gear sets from bams site
mars 07-21-2006 11:20 PM
Re: Bravo1 Noise
Hi it looks like I have made myself misunderstood or haven't wrote properly, what I meant was that number for my serial starting with OL000, the gear kit part number was replace by another one and what I can understand about the new number it is for thicker gears and the price of these are much higher. If you care to take a look at these two links and tell me if I am on the right track, the item number 24 DRIVE SHAFT HOUSING AND DRIVE GEARS and the second one BRAVO GEAR CHANGE
And some metal was found so disassembling, cleaning and inspecting the lower has been done
