-   -   Battery Charger in Late 80's Cig (https://www.offshoreonly.com/forums/general-q/135983-battery-charger-late-80s-cig.html)
gripit 07-24-2006 08:10 PM
In my 88 Bullet there is a battery charger in the engine compartment. It is basicly a big black battery charger. Does anybody know any info about these chargers? Specifically are they trickle chargers or ? Also, my batterys went totally dead because I left the radio on and was wondering how long to leave that charger on so it doesn't cook the batterys.
drypipetiger 07-24-2006 08:15 PM
Re: Battery Charger in Late 80's Cig
on my rig where the battery switches are there is a volt gauges... to keep track while charging.
I don't find mine to be a trickle charger... It charges very quickly. It's important not to overcharge.
gripit 07-24-2006 08:20 PM
Thanks Drypipe,
I also have a volt meter between the battery switches. I just don't know if the charger will turn off when it reaches max. charge.
drypipetiger 07-24-2006 08:25 PM
I don't find that mine does.
Doesn't your altinator charge? The radio only uses juice from one battery. When we're anchored if the battery gets to low to start I start from the other battery then switch to the low batt and it charges on the way to the launch.
gripit 07-24-2006 08:33 PM
True, I do the same thing wile anchoring out. The only thing is that I left the radio on mute all week long so the batterys are totally dead. I had them on the charger for like the last 7 hours.
drypipetiger 07-24-2006 08:38 PM
I see... Well that should be plenty. Check your gauge where the switches are. I wouldn't trust that it would shut off automatically.
JS232 07-24-2006 08:40 PM
It's an alternator not an altinator Shakespeare :rolleyes: :evilb:
drypipetiger 07-24-2006 08:42 PM
1 Attachment(s)
He new what I meant... Why aren't you at the gym?? :evilb: :evilb: :D
JS232 07-24-2006 08:49 PM
1 Attachment(s)
Why don't you let the electrical experts answer His question and keep your advices for plumbing problems M. Magic Crack plumber? :evilb: :evilb: :D
