-   -   Why does my bow bounce when my trim is up high (https://www.offshoreonly.com/forums/general-q/136039-why-does-my-bow-bounce-when-my-trim-up-high.html)
LS1 MOLESTER 07-25-2006 10:36 AM
Seems like i get better speed the higher my trim is set.. but sometimes even half-way up the now starts bouncing up and down like crazy then i have to pull the trim down to stabilize the boat.
Why does it do this?
BajaRunner 07-25-2006 10:45 AM
Re: Why does my bow bounce when my trim is up high
its called porposing. first thing i would look at are the props.
its trying to carry the bow, then dropping it, then carrying it.
LS1 MOLESTER 07-25-2006 10:53 AM
I have a total no name prop that came with the boat.. another reason why i need a steel one..
Thanks for the info.
Canada Jeff 07-25-2006 02:36 PM
Why don't you tell us what the boat is, power, drive,........
HiPerf2000 07-25-2006 02:42 PM
it's called the laws of physics.
ratman 07-26-2006 10:35 AM
oh snap...einstiens is in da house :evilb:
LS1 MOLESTER 07-26-2006 11:35 AM
Baja Force 235, 330HP 454ci, bravo 1 outdrive.
The prop that came with it is new.. my buddy who knows props says it's a POS $2 prop..
Payton 07-26-2006 05:49 PM
There should be a number stamped on the side of the prop that will tell you the pitch.
mats 07-27-2006 03:49 AM
I have the same boat and it used to have the same engine. What speed and rpm do you get at WOT? Also, the prop that you have , is it stainless steel or aluminum?
GeeterB 07-27-2006 05:14 AM
The faster you go...The more you can trim it up...Prop will help too....mess with your cruise speeds and vary the trim...MHO
