Holding tank install ??
I am going to be installing a holding tank in the floor of my 342 soon. Is the anything special to mounting it? I though about putting it in and then spraying insullation around it to sort of fill in all the space so it doesn't move around. I looked at my fresh water tank and it looks like there are just a couple of pieces of angle holing it in. Doesn't seem to good of an isntall but it seems to work.
Also going to isntall this head. Anyone have one? http://www.wilcoxcrittenden.com/sani...wport.asp?bid= Any suggestions? |
Re: Holding tank install ??
I went with one that came with the anti siphon valve so nothing backs into your fresh water system. Also went with one that has the push button switch rather than the pedal type. VERY easy install. Got it through boaters world, forget the model..... looks great and works great... anything you can do to mount the tank to assure it doesn't move around... do it! The model toilet I got comes in two sizes, I got the smaller... I'd go with the bigger one if I could do it over again. It's only a bit larger, but I think it would be worth it...
| All times are GMT -5. The time now is 07:16 AM. |
