Excessive blowby
Has anyone running a blower ever blew out their intake gaskets? I'm hoping thats what happend to me. After a hard run this weekend i'm blowing oil out my breather when I run hard. It also has a very slight miss now.
Re: Excessive blowby
Could be a dead cylinder - bring a compression tester and/or leakdown tester.
That is either from too small or badly designed breathers, but more likely from a problem with the rings or a piston. Blowing out an intake gasket is a small possibility, not likely with most marine blower setups. |
Seriously, it is probably either a burnt piston or a bent or "tuliped" valve due to heat. Intake gaskets dont blow....either it got lean or you had too much timing or both.
Kennyo -
Don't tear your motor down just yet. I put a Whipplecharger on a stock 502 and had serious blowby. Sometimes, the dipstick would blow out of its tube. Since then I had the motor rebuilt (it's a long story) and still get some blowby after a long hard run. Your breather setup is key. Hopefully you are not getting water in your oil. That is a sign of another problem. |
| All times are GMT -5. The time now is 04:18 PM. |
