-   -   bravo1 question (https://www.offshoreonly.com/forums/general-q/136478-bravo1-question.html)
tuffenuff355 07-30-2006 04:30 PM
bravo1 question
went out last thurs on the boat put it back in the slip everything wasn fine. Tried to go out today and have no fwd or reverse, the cable from the shifter to the linkage is doing its job but the cable from the kinkage into the drive is real stiff no play cant even move by pulling on it while its off the likage, my thoughts are of course there is somthing wrong inside the drive or where the cable hooks to the shift mech. any thoughts of what the cause is and how easy a fix it would be would be greatly appreciated,
Longrange4u 07-30-2006 04:44 PM
Re: bravo1 question
Had the same problem.... I had to remove the outdrive and reseat the pin that engauges in the shift linkage. Little tricky bud didnt have to pull the outdrive all the way out... just an inch. Then removed the cap on the front of the outdrive and pushed the shifter forward forcing it to engauge and clamp down on the shifter pin on the end of the cable.
Dont know if the terms are all rightt... but hope this helps.
GOODT 07-31-2006 06:30 AM
Re: bravo1 question
more then likely a bad lower shift cable
tuffenuff355 07-31-2006 05:50 PM
Re: bravo1 question
thank you bolth for the reply hopfully your input will help me fix it, hasnt been much of a season for me. Its been one thing after the other. nothing major so far but its setting me back on planned trips with freinds.
blue thunder 07-31-2006 07:29 PM
Re: bravo1 question
Look behind the engine while it is running and make sure the driveshaft is spinning. If not, blown coupler.
BT :cool:
Longrange4u 07-31-2006 08:38 PM
Re: bravo1 question
I would do two things...
1: Can you spin the prop now (with your hand while its off) in both directions? If it only spins one way then I think you are having the same situation I am. If you can spin it freely both ways then it may be the cable.
2: (If you can only spin it one way) Take the rearward cap off (requires you to remove the top cap first I think) and see if the outdrive is in gear.... you can push / pull on the selector to see.
GOODT 07-31-2006 08:47 PM
Re: bravo1 question
Might be a good Idea to drain the drive first ............. :drink:
Longrange4u 08-01-2006 12:55 AM
Re: bravo1 question
Yea.... I just put a catch pan under the drive last time... it would be easier to drain it first :evilb:
tuffenuff355 08-01-2006 05:23 PM
Re: bravo1 question
thanks again for your replys, just got back from the marina mechanic says its a blown coupler, another set back but will soon be back in the water.
