-   -   No oil pressure @ idle (https://www.offshoreonly.com/forums/general-q/136603-no-oil-pressure-%40-idle.html)
e8411a 07-31-2006 04:46 PM
I recently started having a problem with the port engine's oil pressure. It runs about 10 psi lower than the starboard engine. After running hard it drops to 0 psi at idle. I already eliminated the sender and the gauge as the culprit by installing a mechanical gauge. Are there any quick tests I can do before I have to yank the motor?
GOODT 07-31-2006 04:59 PM
Re: No oil pressure @ idle
not really, sounds like A bad oil pump or bad bearings...either way it gotta come out
e8411a 07-31-2006 05:26 PM
That's pretty much what I figured. How can I tell if the bearings or the pump are bad?
GOODT 07-31-2006 05:38 PM
pull the oil pan and check them
blue thunder 07-31-2006 07:30 PM
Chisel open the oil filter and look between the pleats for the flakes of death.
BT :cool:
e8411a 07-31-2006 08:10 PM
BT
"Flakes of Death" will mean bearings?
GOODT 07-31-2006 08:32 PM
yes bearing particals but either way the pan has to come off
e8411a 08-01-2006 12:29 AM
OK,
I pulled the oil filter and I can see bronze or brass particles in the oil. I've already started to pull the motor. Thank you GOODT and BT for helping me to isolate the problem
GOODT 08-01-2006 12:38 AM
you are very welcome, if you need anything dont hesitate to call or email
cloudmaster_321 08-01-2006 10:21 AM
would your low oil pressure alarm go off on you as well?
