-   -   FAST(tm) O2 meter (https://www.offshoreonly.com/forums/general-q/136811-fast-tm-o2-meter.html)
Bad Girl 08-02-2006 11:29 AM
FAST(tm) O2 meter
Anyone have used one of these portable O2 meters for checking your air/fuel ratio?
thanks
nordic95 08-03-2006 09:09 PM
Re: FAST(tm) O2 meter
I purchased an Innovative wide band O2 data aquisition hand held recorder from summit racing.Works great,check out my link below.
Thanks Nordic95
http://www.offshoreonly.com/forums/s...sensor+install
Bad Girl 09-05-2006 11:01 AM
What is the ideal cylinder and or distance you can place the sensor to get a god reading??
thanks
mopower 09-05-2006 05:27 PM
I have an Innovate O2 meter and made up a 1" aluminum spacer between the manifold and elbow drilled the side over the valve cover and threaded in the sensor. Works great :D
nordic95 09-05-2006 06:45 PM
thanks
As long as it is a heated sensor(5 wire) you can locate it further back from the heads,like in the elbow or pipe to the transome.
Nordic95
mopower 09-06-2006 11:37 AM
Nordic95
Gotta by dry...no water mixed with exhaust :cool:
