-   -   Setting Timing Delco Voyager (https://www.offshoreonly.com/forums/general-q/137026-setting-timing-delco-voyager.html)
BLACKHAWK 001 08-04-2006 03:31 PM
I Removed the EFI from my 502 and iam using the delco distributor that was used with the EFI. I purchased the pigtail to set base timing. I set base timing to 10 degrees, the module is suppose be 22 degrees, but iam only seeing 22 degrees total at 3000 rpm. Shouldn't I be seeing 32 degrees ?
SB 08-04-2006 03:35 PM
Re: Setting Timing Delco Voyager
I just did the same thing and can't remember for life of me the advance of the module. I do remember the advance was all in just before 2800rpm to 3000rpm though.
Sorry for the pea brain.
SB 08-04-2006 03:38 PM
Now I know why I don't remember. Took me a second. On the dyno I set total timing and did not worry about initial. A few dyno sessions later I installed a Crane HI-6M (i bypassed the module - just used the magnetic pick-up).
So I'm of know help other than saying the HI-6M is the cat's azz !!!!! :D
GOODT 08-04-2006 06:11 PM
yes you should be seeing 32 deg total timing if set at 10 deg advance base timming, try taking it up to 3400 rpms and see where you are at ( thats about the top of the advance cure possible)
BLACKHAWK 001 08-04-2006 08:51 PM
I set the total advance to 32 degrees the engine idles better,thottle response is better and the the engine sounds better,cranks and starts good. I am just worried I am missing somthing. I dont want to damage the engine by over advancing. Base timing is now set to 20 degrees! I reved engine to almost 4000 rpm but wont advance any more.
Thanks for your helpful responses Scott
GOODT 08-04-2006 11:29 PM
base is 20 deg ????????????????????
some thing wrong there.......................
base should be 8deg 10 -12 max .....and 12 is really pushing it
Dave_N 08-05-2006 06:49 PM
If you are checking base timing, be sure that you shut down the engine, remove timing tool and then restart before checking advance.
Dave
SB 08-07-2006 07:37 AM
If Voyager is used without a computer, I believe you don't need to use the 'timing lock out' tool. The module inside computer works like other modules (like a TB IV) does.
I went the HI6M because of choices of advance curve, rev limiter, and etc. Really is a great upgrade !
Dave_N 08-07-2006 10:20 AM
You still need to use a timing tool for a precise adjustment, the Delco Module will be advancing a few degrees even at idle speed.
Dave
TwoKs 05-25-2015 11:50 AM
When using a delco voyager dist without computer,just module inside distributor.I want to do base timing I know I have to plug in the lockout tool. Here is my problem do I ground the wire or do I put the wire to positive. Dennis Moore book says to ground but on internet it says to hook up to positive on u tube and other sites Any body know cause I don't want to burnout the distributor or module
