Big Block Circulating Water Pump
1 Attachment(s)
Today my circulating water pump started to drip from a hole under it. (Picture). The engine has not closed cooling.
Is there something I can do, or do I need to replace it? Can I use a automotive pump or does it have to be a marine one? If any, what are the difference between them? Thanks |
Re: Big Block Circulating Water Pump
You need to replace that pump. The internal seal is bad and will only get worse. I would use a marine pump. The difference is the marine pump had a stainless impeller and backing plate.
Ordering one right now. Thanks for the info.
True, what he said |
My question is, why not just put a cross over on instead of using another circulating pump?
Happened to mine as well 1968 corvette 427 pump. changed one on my small block years ago with a corvette small block pump also a 68. Both have run fine and fit perfect with no problems
| All times are GMT -5. The time now is 07:24 PM. |
