-   -   gear ratios (https://www.offshoreonly.com/forums/general-q/137193-gear-ratios.html)
tomcei 08-06-2006 08:06 PM
gear ratios
Are the lowers in xr, xz bravos the same?
Are the gear ratios 1.5 and 1.36 made in the lower or the upper? or is it a combnation of gear sets in the upper and lower that give you your ratio?
rbtnt 08-06-2006 08:20 PM
Re: gear ratios
Here is a link to a page of Mercury gear ratios that should answer your questions.
http://www.mtboats.com/outdrivegearratios.html
tomcei 08-06-2006 09:44 PM
Re: gear ratios
thanks, I didn't see an XR with a 1.36 I assume they exist??
Anyway my underlying question would be... Could some one mate a XZ upper 1.5 to a XR lower that was from a 1.36 and end up with some kind of hybrid or would it turn into a 1.36 or what? I know it would help if I knew what XR lowers were available.
I think I may have a miss matched gear set if that's possible.
I had an XZ 1.5 and put on an XR lower after I blew out the XZ lower and I have some wierd results.
rbtnt 08-06-2006 10:06 PM
Re: gear ratios
XRs are available in 1.50, 1.35 and 1.26 depending on the lower gear ratio.
Your combination should end up at 1.34 by using the table in the link.
XZ 1.50 will have 32/27 gears in the top
XR 1.35 will have 15/17 gears in the lower
Match those in the table, you will have 1.34 ratio.
tomcei 08-07-2006 07:19 AM
Re: gear ratios
thanks, I miss read the chart
