-   -   500 Efi What Is Too Hot (https://www.offshoreonly.com/forums/general-q/137447-500-efi-what-too-hot.html)
chad1 08-09-2006 01:43 AM
Lost A Hose On The Sea Pump At High Speed.computer
Shut Down The Motor. I Replaced The Sea Pump Kit
And Motor Seems To Run Fine. Sometimes It Feels A Little Down On Power. But Its Hot Out.
It Got To 240 Ish On The Gauge. What Temp Does The Computer Shut The Motor Down? Should I Be Worried About Head Gaskets?
Wobble 08-09-2006 10:30 AM
Re: 500 Efi What Is Too Hot
Sounds like you got away with it, I think the computer goes into limp mode in the 200-210 range.
If you are concerned, a compression test and a leakdown test will give you a good idea of the motors health. Assuming that there is no water in the oil.
It would be a good idea to get some fresh oil in it as soon as possible
customryder 08-09-2006 11:52 AM
your OK
chad1 08-09-2006 01:05 PM
oil was changed also. whats acceptable on leak down?
chad1 08-09-2006 08:41 PM
WHAT SHOULD COMPRESSION BE
