info on Volvo 600 dpx package
I have looked thru the back threads and found some decent info but am looking for updated information. I am looking at a boat with this package and while I have no fear about the motors, I am a little concerned about the outdrives. I see that guys have had good luck in the past but am wondering about rteplacement parts, if necessary, and anything else that might be an issue. I have no first hand experience with this package. Hopefully somebody can help me out?
Thanks, Mark |
Re: info on Volvo 600 dpx package
Thanks, Mark www.LakesideRestorations.com |
Nobody hear that can relate their experiences with at least the DPX drive? I realize the volvo 600 motors are not very common, but somebody must know somebody who has DPX drives????
Thank you Lakeside for the info. Regards, Mark |
Innovation Marine built the 600's for Volvo. I believe that Volved stopped production on this package due to the drives not holding up to the 600 hp.
Yes, I am definitelt not afraid of the engines, except maybe from a resale perspective, but its hard to be afraid of Innovation built stuff. The drives are what worries me. this is what I am trying to get peoples experience with. the kind of thing you are talking about. thanks Otis311
Regards, Mark |
The German Hustler dealer had those engines / drives in his 388 Slingshot
Feel free to contact him for more accurate info [email protected] I remember, engines were nearly bulletproof :D ...but he broke a drive :mad: |
Thank you. Thats kind of what I am afraid of. I will shoot him an email.
Regards, Mark |
Regards, Mark |
Regards, Mark |
Regards, Mark |
1 Attachment(s)
Does the engine in your application look like this?? Its a DPX with a 600 Volvo..
Volvos are TOUGH drives. I would take a DPX over a Bravo any day of the week. I would have more peace of mind with 700 hp in front of a Volvo than I would with 500 in front of a Bravo! Built in external steering is sweet too. IMO Volvo was ahead of their time with the 500 and 600 DPX packages but just couldn't bust into the hi-po market thet Merc owns. |
According to the German Hustler dealer, his 388 Slingshot was 5 - 7 mph slower :mad: :mad: with the DPX drives then same powered 388 Slingshots with Bravo XR's....
I too am a fan of most of the VP stuff.. Bravos & Alphas dont have oil circulation pumps either.
The duo prop design can add a little drag compared to a single prop drive.. J / lakeside :) |
My old boat had a single prop SX drive and my friend had the same boat with a DPS duoprop(not DPX) and our top speeds were identical. Not saying that's normal but that was my experience in a small single V-bottom. If you're losing 5-7 mph it's setup IMO.
In the < 70 mph zone maybe.. Even with a Merc Bravo 3 it will be hard to go faster then 65 - 70 MPH ....
Merc also recommands B3 drives for boats only up to 65 MPH... Twin prop drives (Merc or VP) are not suited for speeds + 90 MPh like a 388 Slingshot does... |
Thanks for the info guys. I know that the boat runs in the 93 mph range. This is confirmed by Powerboat when they tested the boat in 1999. They were very favorable of it with the 600 DPX package. does anyone have a tel # for Innovation Marine? Thanks.
Regards, Mark |
Innovation Marine's phone number is 941-355-7852
Originally Posted by noboat
The only drive failures that were occuring happened when the X dimensions were raised too high in an attempt to squeeze out every last 1/10 mph and the drives became surface piercing, which they are not designed to do. This created a harmonics problem and led to a few drive failures.
Thanks for the info and the tel#
Regards, Mark |
How many hours are the 600's good for? Any top end concerns like head gaskets?
I had what might have been a head gasket issue on one of my 600's early on. (The engine was rebuilt under warranty, and I was not supplied any details.) Since then, I put another 400 hours on the engines with no issues. I had the heads pulled for inspection/valve job and springs, and have run another 250 hours with no issues. Still haven't touched the lower ends. Innovation claims to have a set on the west coast with over 700 hours and counting. These engines are highly regarded by anyone who has owned them.
So you have 650 hours on a pair now?
3 Attachment(s)
Spent some time driving the 382 now and I'm impressed with the 600 EFI's. Talked to Dave Stiff at Innovation Marine and he emailed me some info on the motors.
Good looking with Stelling headers too! |
I believe I have around 300 or so on mine and other than a few clogged injectors, and 1 heat exchanger I have had 0 issues and they are untouched. I did a compression check over the summer for giggles and they are still very good at +/- 165 each.
3 Attachment(s)
Originally Posted by eddie
(Post 3797454)
Good looking with Stelling headers too! My engines are at 664 hours. I repainted and converted them to serpentine belts while they were out for a re-rig. I also scored the only two top shrouds ever made while I was at Innovation this spring... :) |
1 Attachment(s)
Originally Posted by C_Spray
(Post 3798056)
Eddie - That particular boat was converted to Bravos, correct?
My engines are at 664 and 564 hours. |
(Post 3798058)
Correct, it has Stelling Boxes and Bravo XR's.
(Post 3798073)
Is it still for sale? It was priced very right...
(Post 3798079)
Lots of calls on it, but no one has pulled the trigger. It's a nice boat 100% freshwater and one owner with a trailer. It's got Bravo I 30 pitch (restamped 33) props on it, I'm told with some other props it runs mid 80's. Best I've seen is 72, will it hit 80's with different set of props?
I went with the DPX's for cruise efficiency and reliability, and they have not disappointed me in the least. They are awesome around the docks as well. |
| All times are GMT -5. The time now is 09:03 AM. |
