-   -   Hardin Marine water pump on a Whipple Help (https://www.offshoreonly.com/forums/general-q/137624-hardin-marine-water-pump-whipple-help.html)
MnHowardCat 08-10-2006 10:20 PM
Does any one have some pic's of a Hardin Marine two stage water pump and bracket on a Whipple motor with a serpentine belt???? I want to use one of these pumps but the pulley's don't line up at all I need to make a new mounting bracket and I'm looking for some ideas on what to make The bracket is about 1 to 1 1/2 off Hardin Marine sed I was on my own on geting it line up with a Whipple set up any help would be greatly appreciated
Don
Hardin Marine 08-11-2006 12:42 PM
Re: Hardin Marine water pump on a Whipple Help
3 Attachment(s)
Don,
In the pictures below you will see the dual stage pump with a serpentine drive system on a Whipple Charged motor.
The measurement is 4.010" from the machined face of the block to the first peak. This is with a standard sea pump pulley.
If your measurement is the same or greater a spacer can be used. If it is less than 4.010" then I don't know of a way to move it closer to the engine without building a custom mounting bracket or a custom pulley with a deeper offset.
If you have any questions or need some more help please call Rick in our California office at 707-585-9006 and he can explain it further.
MnHowardCat 08-11-2006 04:11 PM
Thank's for the help
Don
