Re: Proper 500HP Carb
The newest cam will be fine and you should have no problems with reversion. You could even go bigger. I definately would.
My cam is a Crane 168731. Its .587/.610, 226/236, 112 lob sep and its in 454. Idles at 700rpms in gear and no problems with reversion. I would not go any smaller than this for 490ci. |
when we went through my 500hps we used 850 cfm marine demons I am prsently at 565hp
Originally Posted by SB
LSA effects valve opening / closing points which also gives us your overlap and 'where it is.' Without your seat #'s we don't know these points.
This is why I've ben asking for these. Very critical........especially with boats and wet exhausts. |
Here's a good comparison of 3 Mercruiser hydraulic roller cams. One is for low hp 454's, next is for Magnum 454/502 motors, and third is for the 502 HP500 (carb) . Take a good look at the .004" , .006" seat #'s , .050" #'s, lift, etc,etc
If we just went by .050" #'s we'd probably make incorrect assumptions about all the rest of each cams spec's. Also, since most manufacturers don't come out and tell you what the seat °was taken at (.004", .006" or what have you) imagine if you where told cam #1 had 280°,299° advertised duration and cam #2 had 288°, 288° seat duration. We'd be screwed !!! This is why all of us, when comparing cams, we need to know where the seat ° durations are taken at. Impossible to compare two cams without EXACT info. Merc Std BB Roller .004 280,299 .006 266*/284* .050 204*/209* .200 113*/114* Lift .480/. 483 ICL 115.5* ECL 120.5 LSA 118* Merc Mag Roller .004 300*/ 300* .006 288*/288* .050 225*/225* .200 125*/125* Lift .483/. 483 ICL 109* LSA 115.5* .. Merc HP500 Carb Crane Gen VI#169611 Grind#HR-284-2S-10IG Adv 284, 292 at .004 Lift with 1.7 .576 / .598 At .050 222, 230 ICL 105, ECL 115 LSA 110 |
My cam is a Crane 168731. Its .587/.610, 226/236, 112 lob sep and its in 454. Idles at 700rpms in gear and no problems with reversion. I would not go any smaller than this for 490ci. Merc 500EFI Gen VI #169621 Grind#HR-292-2S-14 IG 292,298 at .004 Lift with 1.7 rocker .598 , .610 230, 236 at .050 ICL 109 , ECL 119 LSA 114 It appears to be similar except for a little more intake and lobe separation. Since I wouldn't mind sacrificing a little top end for more assurance of a better idle and no reversion, maybe this is my best bet. Of course that's where I started in the first place. With the HP500EFI cam, just not the specs I thought that cam had. thanks again everyone |
Similar - Let's look closer.
Hp500.....731.....500EFI #19611...#168731...#169621 Note: figures below include cams ground or installed 5°advanced IVO...33BTDC....33BTDC.....33BTDC IVC...71ABDC....75ABDC.....79ABDC EVO...77BBDC....82 BBDC....84BBDC EVC...35ATDC....36ATDC....34ATDC 68°......69°.....67° overlap measured from .004" 105°....107°....109° intake centerline 115°....117°....119° exhaust centerline 284°.....288°....292° intake seat duration at .004" 292°.....298°....298° exhaust seat duration at .004" 222°.....226° ...230° intake duration at .050" 230°.....236° ...236° exhaust duration at .050" |
In case one hasn't logged in I edited info to include the 731 as was being compared. Sorry. So please log in to see the 3 cams side by side with each other. Kind of interesting anyway when looking at them this way.
Bc, Talk to Tyler about Quickfuel Carbs. They know how to build them. They engine test each one. They will be cheaper than a stock Holley or Demon. Mine on my previous boat felt like fuel injection. Tyler can order one set up perfect for your app.
" Actual power output would probably depend on the In/Exh flow balance of the heads, but the 500EFI would probably also idle a tad better and make a little more torque down low. The 731 might pull it at the top end if the heads were intake dominant. Then again that might just be mental M@$terbation given that who really knows what a cam will do in an engine. |
| All times are GMT -5. The time now is 08:42 AM. |
