-   -   2006 496HO Oil Drain Plug (https://www.offshoreonly.com/forums/general-q/138275-2006-496ho-oil-drain-plug.html)
Fountaineer 08-18-2006 02:21 PM
Does anyone know the size of the oil drain plug threads on the side of the oil pan of the 2006 496HO?
Reckless32 08-18-2006 03:11 PM
Re: 2006 496HO Oil Drain Plug
Hmmmm. Don't know the size of the plug, but I'm curious, what happened to the one that came with it along with the drain hose adapter that can be pulled thru the transom plug hole?
Pismo10 08-20-2006 08:47 AM
Why are you assuming he lost his? I see nothing in the post about that, just what size.
Fountaineer 08-21-2006 06:20 PM
I'm installing a pre-oiler pump and replacing the small factory hose with a larger diamter hose and fitting. I'll know what size it is when I pull it out but I was hoping someone would know the size so I can order the part I need.
