who wants to lend me a 496ho scan tool
Anyone out there that wants to borrow me a Merc scan tool so that I can scan my motor?
I have one motor that is giving me the 2 beep alarm and I would like to find out for myself what it is and fix it. I am willing to pay for all shipping costs back and forth. Jeff |
Re: who wants to lend me a 496ho scan tool
I have one motor that is giving me the 2 beep alarm and I would like to find out for myself what it is and fix it. I am willing to pay for all shipping costs back and forth. Jeff bco 496 |
Heres a new twist to this alarm puzzle...We were out 5 hrs Friday with NO alarms, then Saturday (Temp. much hotter that day) it started the 2 beep alarms again..Noticed I cud shut off engine, but leave ignition on and the alarms kept coming..After a half hour or so, NO alarms rest of the day..
????????? BCO 496 |
I'm assuming all your fluids and resevoirs are full.
Im getting the same alarm on a 350 mag motor,two short beeps every 2 minutes.All fluids are good and gauges are right where they should be.
This is getting scary! See my post under the 350 Mag thread about the 2 beep alarm. Just bought a boat with a pair of '02 6.2MX motors and during the sea trial (about .7 hours run time on motors) the alarms never went off. Got it home and within 5 minutes after loading the family in the boat, started getting the 2 beep alarm on starboard engine ... disconnected the drive bottle sensor, so I know it is not that (and the drive bottle was at the "full" mark anyways. Manual says that is the only thing that will give a 2 beep signal. Talking with Mercury Tech Assistance was of no value whatsoever ... :rolleyes:
had a few water temp sensors go bad drove me nutz and theyre only plastic so be careful taking them out
This boat is a year old with 125 hours and dry stacked.Motor compartment is dry as a bone.
might be a H20 pressure sensor mounted in the cooler behind bellhousing.
had a few go bad, 2 beep alarm but usually goes into guardian mode and rpms wont go over 4000 rpm. without a scanner, disconnect elect connector and ohm out, if its open replace it with a scanner h20 pressure will read 0 hope this helps by the way - sometimes doesnt store a hard code |
| All times are GMT -5. The time now is 04:44 PM. |
