-   -   Adjusting lifters 1/2 3/4 maybe more? (https://www.offshoreonly.com/forums/general-q/138738-adjusting-lifters-1-2-3-4-maybe-more.html)
BadDog 08-24-2006 05:31 AM
Crane lifters and rocker arms. Got a few noisy ones. Ran the boat an hour to see if they would quite down some. Only have a few that are making a tick a various RPM between idle and 1500. You can sort of hear it if you use a hose held to the ear and rocker tip. I set them back to 0 and then 3/4 turn. Still made noise so I went an 1/8 more on these. Still a little clicking sound. Not bad but the others are silent.
How many turns is the max for tightening down? Might go the max to see if they quite down, if not just back them off to 3/4 and go with it.
Tim T.
DRIPPINWETII 08-24-2006 06:28 AM
Re: Adjusting lifters 1/2 3/4 maybe more?
Tim T.
I have always gone 3/4 of a turn without a problem.
Might want too start over and make sure valves are all the way closed before adjusting.
Vinny P 08-24-2006 07:36 AM
I would call Crane and ask them where they want them set to.
Wobble 08-24-2006 09:10 AM
Are these new heads / valves /guides.
My buddy kept chasing a noisy lifter, turned out it was a badly worn valve guide, valve was getting cocked on seat (noise) eventually it broke and destroyed the motor.
I would think 1/2 turn after zero lash would be fine for hydraulic lifters. If they are solid then you need to set the old fashioned way :D
woody1 08-24-2006 09:25 AM
1/2 to 3/4th and make sure the liftter is on base circle when adjusting
BadDog 08-24-2006 09:32 AM
Fresh heads and rockers, lifters have maybe 50 hours on them. Fresh motor, forge pistons, new rods etc.
SB 08-24-2006 10:20 AM
Flat tappet or Hydraulic roller or something else ?
Roller rockers or stamped steel ?
BadDog 08-24-2006 10:47 AM
Crane hydraulic roller lifters and Crane Gold rocker arms.
SB 08-24-2006 11:07 AM
Just so you know - aggresive ramped HR cams (such as most of Crane's ) along with roller rockers can emit ticking noises that are audubile to the ear even without a hose / stethascope. Very, very normal.
Wobble 08-24-2006 11:27 AM
Would you agree that there may be an issue if only one is ticking?
It can get messy, but if you are able to run motor without valve cover on, you can take a balled up rag and cover each lifter in turn to see if it's just one or all of them taking turns.
SB 08-24-2006 11:34 AM
I personally have had no luck this way. They always seem to tick even when you get to the point they are tightened down too far and the engine runs like crap.
Adjust the rocker arms the normal + correct way (two different methods - either is fine) and then move on to diagnosing other parts if you think this noise is still a problem.
Unfortunately noise issue diagnosing over a computer is near impossible - hard enough when looking at it live. So I can only give input which in no means may relate to your situation. Sorry.
BadDog 08-24-2006 01:56 PM
Called crane tech line. Thye said they like one full turn and no more than 1.5 on a BBC. I will give that a shot.
BadDog 08-24-2006 08:00 PM
OK, adjusted to 1 1/8 and they are good now.
