-   -   Tab & Trim Cable Replacement ? (https://www.offshoreonly.com/forums/general-q/138949-tab-trim-cable-replacement.html)
J.B. Marshall 08-27-2006 01:02 PM
I have a 02 - 382 Fastech and want to change the tab & trim cables. I have thought about tackling this on my own are there any how to manuals for this? What would I expect to pay for this to be done at a shop?
J.B. Marshall 08-28-2006 01:21 PM
Re: Tab & Trim Cable Replacement ?
Ok, Does anyone know the length of the cables that will be needed. I would like to have them on hand as opposed to pulling out the old to measure for the size.
t500hps 08-28-2006 02:24 PM
I replaced them on my 31 not that long ago. If you inspect the length of the cable you will find some numbers printed on the sides somewhere. (mine were red cables with white numbers) Formula tech support can also tell you what length cables you need. If you can take them out I'm willing to bet you can figure out how to put the new ones back in........
Ted G 08-28-2006 02:37 PM
Cable number is near the ends and will have the length in inches. Get a coupler from the hardware store that fits the end, then screw the cables together into the coupler and use the old cable to pull the new one through. For your shifts and throttles use Teleflex TFXtremes-you'll be glad you did-they are smooth as a baby's butt.
J.B. Marshall 08-28-2006 02:41 PM
Thanks for the help.
JB
Strip Poker 388 08-28-2006 05:52 PM
I did mine with the motors out but prob could of done it with them in pretty good.Heres some picks .Also the had silicone on the inside going thru the transom,I would get the rubber inserts from merc also,.That the seal on the out side .Try calling Formula I talked to Hustler on mine they were real helpfull.also gave me the lenghts and the new updated cables
Good luck
Rob :drink:
post 26...................http://www.offshoreonly.com/forums/s...ad.php?t=92301
