350 Mag goes into Guardian Mode - Help Please
I've got a 350 Mag that goes into guardian mode about 3000 rpm. The computer is not showing any error codes. Any one have similar issues or thoughts?
Re: 350 Mag goes into Guardian Mode - Help Please
Check for a bad neutral safety switch. If they see neutral they will not go over 3000, and will not code. Unplug the switch and see if it fixes it. If it does it may be that the lever that switches the switch is over-traveling and the switch is dropping off the back side. Don't ask me how I know this :D
Are you sure it's going into Guardian Mode? Is there an alarm when this happens? What codes are currently in memory? What is the frequency count for each one?
You could try clearing the Freezframe memory and retesting. If you get an alarm/Gaurdian Mode again, it should be easy to figure out why after rechecking the memory and reveiwing the newly stored faults. If you get an alarm and there are no faults stored, there may be a problem with the ECM, but thats not very common. Taking a wild guess, it sounds like a possible problem with the shift position switch. If the ECM thinks the engine is in neutral, it will limit RPM to 3500. But you should have a stored Neutral Overspeed fault if that was the case. Again, this is just a guess, there are other faults (ECT Overtemp, Low Drive Lube, Low Oil Pressure) that could be causing the power reduction. Dave |
Thanks for the feedback. I'll let you know what I find.
J |
I had a 350 Mag in my old boat and it did something similar at 3000 rpm. Sounded like the rev limiter kicked in or something. Turned out to be a loose plug wire. Check those, all of them including the main one. That's what it was for me.
350 mag issue no start
hi , ihave a boat with 2 engines 350 mag the 02 engine do not want to turn on i scanned the engines i have the following code on both of them
Current ECM Codes Sensor Fault, click Read Fault button for details Trouble Code List: PITOT CKT LO Code is active FUEL LVL CKT HI Code is active STEER CKT LO Code is active SEA TMP CKT HI Code is active TRIM CKT HI Code is active i test the injectors with the diacom from 01 to 04 injector test good, but from 05 to 08 i cannot test them ,the same result on the 02 engines,please let me know if you have any suggestion. engine 01: Parameter Description Value Unit Engine Speed.......................................... 0 RPM Available Power..................................... 100 % Coolant Temperature............................... 75,20 °F Fuel Flow Rate..................................... 0,00 GPH Port Exhst Cool Temp.............................. 32,00 °F Sea Pump Pressure.................................. 0,00 PSI Starb Exhst Cool Temp............................. 32,00 °F IAC Duty Cycle..................................... 0,00 % Manifold Absolute Pressure........................ 14,80 PSI Trim Position...................................... 1023 # Baro Pressure..................................... 14,80 PSI Trim Volts......................................... 4,99 VDC Manifold Air Temperature.......................... 78,80 °F Pitot ADC............................................. 0 # Oil Pressure....................................... 0,38 PSI Paddle Wheel.......................................... 0 Hz Throttle Position.................................. 0,00 % Sensor Power....................................... 5,06 VDC Throttle Sensor Voltage............................ 0,63 VDC Lake/Sea Temp..................................... 32,00 °F Spark Advance...................................... 8,00 DEG Fuel Level......................................... 1023 # Battery Voltage................................... 11,25 VDC 3. TROUBLE CODE STATUS Current ECM Codes Sensor Fault, click Read Fault button for details Trouble Code List: PITOT CKT LO Code is active FUEL LVL CKT HI Code is active STEER CKT LO Code is active SEA TMP CKT HI Code is active TRIM CKT HI Code is active engine 02 2. PERFORMANCE DATA Parameter Description Value Unit Engine Speed.......................................... 0 RPM Available Power..................................... 100 % Coolant Temperature............................... 75,20 °F Fuel Flow Rate..................................... 0,00 GPH Port Exhst Cool Temp.............................. 32,00 °F Sea Pump Pressure.................................. 0,00 PSI Starb Exhst Cool Temp............................. 32,00 °F IAC Duty Cycle..................................... 0,00 % Manifold Absolute Pressure........................ 14,57 PSI Trim Position...................................... 1023 # Baro Pressure..................................... 14,57 PSI Trim Volts......................................... 4,99 VDC Manifold Air Temperature.......................... 78,80 °F Pitot ADC............................................. 0 # Oil Pressure....................................... 0,54 PSI Paddle Wheel.......................................... 0 Hz Throttle Position.................................. 0,00 % Sensor Power....................................... 4,99 VDC Throttle Sensor Voltage............................ 0,64 VDC Lake/Sea Temp..................................... 32,00 °F Spark Advance...................................... 8,00 DEG Fuel Level......................................... 1023 # Battery Voltage................................... 11,11 VDC 3. TROUBLE CODE STATUS Current ECM Codes Sensor Fault, click Read Fault button for details Trouble Code List: PITOT CKT LO Code is active FUEL LVL CKT HI Code is active STEER CKT LO Code is active SEA TMP CKT HI Code is active TRIM CKT HI Code is active there is pressure on the fuel pump the startor good spark plug new the fuse good thank you to help me best regards |
