Calling Sb
Do You Have The Cam Specs For A Zz502/502
Thanks Patrick. |
Re: Calling Sb
Barely any pertinent info but here is what is published:
224° , 234° at .050" .527", .544" lift with 1.7 rockers 110LSA Steel core/gear - should not use typical cast iron dist gear. =============== That's it - no seat, no events, nothing. It's obviously made for stamped rocker arms - ie: look at lift, sub .550". My wild guess is the seat #'s are pretty large for the corresponding at .050" #'s.. Just a WAG. GM cams are pretty famous for this. |
Re: Calling Sb
224? , 234? at .050" .527", .544" lift with 1.7 rockers 110LSA Steel core/gear - should not use typical cast iron dist gear. =============== That's it - no seat, no events, nothing. It's obviously made for stamped rocker arms - ie: look at lift, sub .550". My wild guess is the seat #'s are pretty large for the corresponding at .050" #'s.. Just a WAG. GM cams are pretty famous for this. |
| All times are GMT -5. The time now is 10:13 PM. |
