Scan results....need help
This is from my one motor that is giving me the 2-beep soft alarm. Can anyone look it over and give me an idea what to look for? I did recently change my broken shift cable ... and it started 2 runs after that cable was changed..
DIACOM ® Diagnostic Status Report 08/30/2006 18:41:25 1. VEHICLE CONFIGURATION Engine Make: N/A Engine Serial No: N/A Model Year: N/A System Type: MerCruiser PCM555 2. PERFORMANCE DATA Parameter Description Value Unit Engine Speed 666 RPM Available Power 90 % Coolant Temperature 158.00 °F Fuel Flow Rate 1.53 GPH Port Exhst Cool Temp 98.60 °F Sea Pump Pressure 43.46 PSI Starb Exhst Cool Temp 98.60 °F IAC Duty Cycle 19.16 % Manifold Absolute Pressure 9.28 PSI Trim Position 0 # Baro Pressure 14.05 PSI Trim Volts 0.00 VDC Manifold Air Temperature 100.40 °F Pitot ADC 0 # Oil Pressure 53.32 PSI Paddle Wheel 0 Hz Throttle Position 0.12 % Sensor Power 4.99 VDC Throttle Sensor Voltage 0.55 VDC Lake/Sea Temp 404.60 °F Spark Advance -6.06 DEG Fuel Level 1022 # Battery Voltage 13.87 VDC 3. TROUBLE CODE STATUS Current ECM Codes Sensor Fault, click Read Fault button for details Trouble Code List: SEA PUMP CKT HI Code is active PITOT CKT LO Code is active STEER CKT HI Code is active TRIM CKT LO Code is active Freeze Frame Data: 0 STEER CKT HI -------------------------------------------------------------------- FF Baro Pressure 14.05 PSI FF Battery Volts 13.25 VDC FF Sea Pump Pressure 23.57 PSI FF Boat Speed 0.00 # FF Manifold Air Temp 95.00 °F FF Coolant Temp 140.00 °F FF Demand 0.00 % FF Engine Speed 0 RPM FF Engine State Stall FF FPC Total 0.0 Counts FF Frequency Count 371 FF Fuel Level 0.00 % FF Gear Position In Gear FF Lake Temp 404.60 °F FF Engine Load 0.00 % FF Main Pwr Relay Requests 4.0 FF Manifold Air Pressure 14.06 PSI FF Oil Level 0.00 % FF Port Tab Pos 0.00 % FF Available Power 100 % FF Run Time 32.63 hrs FF Starboard Tab Pos 0.00 % FF TPS Percent 0.00 % FF Trim Position 0.00 % 1 TRIM CKT LO -------------------------------------------------------------------- FF Baro Pressure 14.05 PSI FF Battery Volts 13.22 VDC FF Sea Pump Pressure 35.48 PSI FF Boat Speed 0.00 # FF Manifold Air Temp 95.00 °F FF Coolant Temp 140.00 °F FF Demand 0.00 % FF Engine Speed 0 RPM FF Engine State Stall FF FPC Total 0.0 Counts FF Frequency Count 310 FF Fuel Level 0.00 % FF Gear Position In Gear FF Lake Temp 404.60 °F FF Engine Load 0.00 % FF Main Pwr Relay Requests 4.0 FF Manifold Air Pressure 14.06 PSI FF Oil Level 0.00 % FF Port Tab Pos 0.00 % FF Available Power 90 % FF Run Time 32.63 hrs FF Starboard Tab Pos 0.00 % FF TPS Percent 0.00 % FF Trim Position 0.00 % 2 PITOT CKT LO -------------------------------------------------------------------- FF Baro Pressure 14.05 PSI FF Battery Volts 13.19 VDC FF Sea Pump Pressure 35.77 PSI FF Boat Speed 0.00 # FF Manifold Air Temp 95.00 °F FF Coolant Temp 140.00 °F FF Demand 0.00 % FF Engine Speed 0 RPM FF Engine State Stall FF FPC Total 0.0 Counts FF Frequency Count 316 FF Fuel Level 0.00 % FF Gear Position In Gear FF Lake Temp 404.60 °F FF Engine Load 0.00 % FF Main Pwr Relay Requests 4.0 FF Manifold Air Pressure 14.06 PSI FF Oil Level 0.00 % FF Port Tab Pos 0.00 % FF Available Power 90 % FF Run Time 32.63 hrs FF Starboard Tab Pos 0.00 % FF TPS Percent 0.00 % FF Trim Position 0.00 % 3 OVERSPEED -------------------------------------------------------------------- FF Baro Pressure 14.42 PSI FF Battery Volts 13.30 VDC FF Sea Pump Pressure 3.49 PSI FF Boat Speed 174.00 # FF Manifold Air Temp 80.60 °F FF Coolant Temp 80.60 °F FF Demand 46.96 % FF Engine Speed 4970 RPM FF Engine State Running FF FPC Total 72.8 Counts FF Frequency Count 1 FF Fuel Level 0.00 % FF Gear Position In Gear FF Lake Temp 404.60 °F FF Engine Load 24.62 % FF Main Pwr Relay Requests 1044.0 FF Manifold Air Pressure 9.85 PSI FF Oil Level 0.00 % FF Port Tab Pos 0.00 % FF Available Power 7 % FF Run Time 11.17 hrs FF Starboard Tab Pos 0.00 % FF TPS Percent 46.96 % FF Trim Position 0.00 % 4 MPRLY OUTPUT -------------------------------------------------------------------- FF Baro Pressure 14.50 PSI FF Battery Volts 6.02 VDC FF Sea Pump Pressure 0.00 PSI FF Boat Speed 0.00 # FF Manifold Air Temp 64.40 °F FF Coolant Temp 64.40 °F FF Demand 0.00 % FF Engine Speed 0 RPM FF Engine State Stall FF FPC Total 0.0 Counts FF Frequency Count 1 FF Fuel Level 0.00 % FF Gear Position In Gear FF Lake Temp 402.80 °F FF Engine Load 0.00 % FF Main Pwr Relay Requests 4.0 FF Manifold Air Pressure 14.50 PSI FF Oil Level 0.00 % FF Port Tab Pos 0.00 % FF Available Power 0 % FF Run Time 10.98 hrs FF Starboard Tab Pos 0.00 % FF TPS Percent 0.00 % FF Trim Position 0.00 % 5 PRT EMCT OVRHT -------------------------------------------------------------------- FF Baro Pressure 14.48 PSI FF Battery Volts 12.44 VDC FF Sea Pump Pressure 0.28 PSI FF Boat Speed 0.00 # FF Manifold Air Temp 114.80 °F FF Coolant Temp 186.80 °F FF Demand 0.00 % FF Engine Speed 0 RPM FF Engine State Stall FF FPC Total 0.0 Counts FF Frequency Count 3 FF Fuel Level 0.00 % FF Gear Position In Gear FF Lake Temp 406.40 °F FF Engine Load 0.00 % FF Main Pwr Relay Requests 4.0 FF Manifold Air Pressure 14.48 PSI FF Oil Level 0.00 % FF Port Tab Pos 0.00 % FF Available Power 6 % FF Run Time 11.40 hrs FF Starboard Tab Pos 0.00 % FF TPS Percent 0.00 % FF Trim Position 0.00 % 6 LOW DRIVE LUBE -------------------------------------------------------------------- FF Baro Pressure 14.57 PSI FF Battery Volts 13.14 VDC FF Sea Pump Pressure 0.00 PSI FF Boat Speed 0.00 # FF Manifold Air Temp 32.00 °F FF Coolant Temp 28.40 °F FF Demand 0.00 % FF Engine Speed 0 RPM FF Engine State Stall FF FPC Total 0.0 Counts FF Frequency Count 1 FF Fuel Level 0.00 % FF Gear Position In Gear FF Lake Temp 404.60 °F FF Engine Load 0.00 % FF Main Pwr Relay Requests 4.0 FF Manifold Air Pressure 14.55 PSI FF Oil Level 0.00 % FF Port Tab Pos 0.00 % FF Available Power 100 % FF Run Time 10.98 hrs FF Starboard Tab Pos 0.00 % FF TPS Percent 0.00 % FF Trim Position 0.00 % 7 STB EMCT OVRHT -------------------------------------------------------------------- FF Baro Pressure 14.00 PSI FF Battery Volts 14.16 VDC FF Sea Pump Pressure 0.55 PSI FF Boat Speed 95.00 # FF Manifold Air Temp 82.40 °F FF Coolant Temp 134.60 °F FF Demand 8.73 % FF Engine Speed 1105 RPM FF Engine State Running FF FPC Total 32.1 Counts FF Frequency Count 0 FF Fuel Level 0.00 % FF Gear Position In Gear FF Lake Temp 404.60 °F FF Engine Load 10.03 % FF Main Pwr Relay Requests 1044.0 FF Manifold Air Pressure 8.05 PSI FF Oil Level 0.00 % FF Port Tab Pos 0.00 % FF Available Power 6 % FF Run Time 11.45 hrs FF Starboard Tab Pos 0.00 % FF TPS Percent 8.73 % FF Trim Position 0.00 % 8 SEA PUMP CKT HI -------------------------------------------------------------------- FF Baro Pressure 14.05 PSI FF Battery Volts 13.22 VDC FF Sea Pump Pressure 31.84 PSI FF Boat Speed 0.00 # FF Manifold Air Temp 95.00 °F FF Coolant Temp 140.00 °F FF Demand 0.00 % FF Engine Speed 0 RPM FF Engine State Stall FF FPC Total 0.0 Counts FF Frequency Count 89 FF Fuel Level 0.00 % FF Gear Position In Gear FF Lake Temp 404.60 °F FF Engine Load 0.00 % FF Main Pwr Relay Requests 4.0 FF Manifold Air Pressure 14.06 PSI FF Oil Level 0.00 % FF Port Tab Pos 0.00 % FF Available Power 100 % FF Run Time 32.63 hrs FF Starboard Tab Pos 0.00 % FF TPS Percent 0.00 % FF Trim Position 0.00 % 9 GUARDIAN -------------------------------------------------------------------- FF Baro Pressure 14.22 PSI FF Battery Volts 14.08 VDC FF Sea Pump Pressure 42.89 PSI FF Boat Speed 76.00 # FF Manifold Air Temp 132.80 °F FF Coolant Temp 156.20 °F FF Demand 98.48 % FF Engine Speed 4597 RPM FF Engine State Running FF FPC Total 78.8 Counts FF Frequency Count 1 FF Fuel Level 0.00 % FF Gear Position In Gear FF Lake Temp 404.60 °F FF Engine Load 35.83 % FF Main Pwr Relay Requests 1044.0 FF Manifold Air Pressure 13.73 PSI FF Oil Level 0.00 % FF Port Tab Pos 0.00 % FF Available Power 90 % FF Run Time 31.28 hrs FF Starboard Tab Pos 0.00 % FF TPS Percent 98.48 % FF Trim Position 0.00 % Fault Log Data Fault Descriptions Seconds Battery Range High: 0 Battery Range Low: 0 Block Pressure is Low: 0 Compressor Temp Overheat: 0 ETC Motor Open: 0 ETC Motor Short: 0 Fuel Pressure Sensor Input High: 0 Fuel Pressure Sensor Input Low: 0 Guardian Strategy: 12 Knock Sensor 1: 0 Knock Sensor 2: 0 Low Oil Pressure Strategy: 0 Low Oil Remote Strategy: 0 Low Oil Reserve Strategy: 0 MAP Sensor 1 Input High: 0 MAP Sensor 1 Input Low: 0 MAP Sensor 1 Idle Rational: 0 Oil Pump Output: 0 Overspeed: 0 Port Clnt Overheat: 0 Starboard Clnt Overheat: 0 Warning Horn Output: 0 Water In Fuel: 0 Engine Run Time History: Total engine run time: 32.65 Hours 0 - 749 RPM: 17.03 Hours 750 - 1499 RPM: 4.35 Hours 1500 - 2999 RPM: 5.02 Hours 3000 - 3499 RPM: 2.37 Hours 3500 - 3999 RPM: 1.87 Hours 4000 - 4499 RPM: 1.77 Hours 4500 - 4999 RPM: 0.25 Hours 5000 - 5499 RPM: 0.00 Hours Over 5499 RPM: 0.00 Hours |
Re: Scan results....need help
BTW, before the beeps, I did have a bad seawater impeller that did result in an alarm of overheat...that impeller was changed and ran fine until the cable broke. If there is a code indicating overheating, that was when the impeller was bad and was probably in the code history. But that was fixed.
You are running in guardian-90 %-since you didnt give specs on the boat -you have codes indicating that you have issues with your transom harness-If you arent using transom harness than the codes that you get for pitot,steering and trim are normal codes and they will always show up on code history-however the reason you are being limited to 90 % and running in guardian is that you have a code for seawater pump circuit high
you should check all connections at sea water pump and look at the connection good-also I dont know what type of boat you are running but by the looks of things you have more run time 1500 to 2900 rpm's that at any other rpm range-did you buy this boat to idle around or are you gonna start running with the dogs!! jam the throttles forward brother or could it be the boats tooooooooo fast for ya??
SEA PUMP CKT HI
Thats the one thats causing your alarm. CKT HI is usually due to open circuit. Start by checking the connector at the sensor for bent pins, water, ect. Dave |
I don't see any evidence of "trouble with the transom harness".
Originally Posted by Dave_N
SEA PUMP CKT HI
Thats the one thats causing your alarm. CKT HI is usually due to open circuit. Start by checking the connector at the sensor for bent pins, water, ect. Dave Oh, and is the motor in the 90% Guardian mode? if so, can I erase the fault codes to get it back to 100%? Thanks much!! Jeff |
Lake/Sea Temp 404.60 °F Just making a funny. Sorry - carry on. |
The sensor on the pump is the Sea Water Pressure Sensor. Thats the one you want to check.
Yes, you are at 90% available power, but you can't just clear the code. A fault code that is "Active" is due to the sensor being currently out of range. Even if you could clear it, the fault would reset immediately. Dave |
Sounds to me like the engine is going bad. I'll give you $50 and take the problems away tonight. :evilb:
Heading to the river this weekend for probably our last trip out there this year. Have a safe and fun labor day weekend. |
Maybe you ought to slap some big ol carbs on them motors and that will get rid of all those silly codes.
By the way just in case you forgot, I still have'nt seen the boat. |
Problem found!
Pressure sensor clip was broke and fitting was open enough to get moisture inside the connections and corrode. I cleaned it out and tested, all OK. Now all I need to do is get a new sensor and put back together. Thanks to all! Hey Ron and Cord .... http://img.photobucket.com/albums/v3...hecing6iz1.gif http://img.photobucket.com/albums/v3...g/P9050007.jpg |
i like happy endings
DIACOM SW is pretty nice! Takes the guesswork out.
u still have one problem-the fact that you arent running the boat like it should be run wot bumpin the rev limiter-
"Sea Pump Pressure 43.46 PSI"
This one jumped right out... 43.46 lbs at idle :eek: Got to love the Diacom :drink: |
That's a nice looking boat Jeff, but I would prefer a beer and a tour, then again I'll buy you a beer if you ever get that thing off of the river and out on the big pond. :drink:
Guess I've had my head in the sand...when did you upgrade to a Sonic?
Deanna and I have been good. This last year has turned around 180 degrees for us. We are both working way too many hours. Gonna have to force some time off before something breaks. |
Originally Posted by hp500efi
Dave, are you talking about the sensor attached to the pump housing that senses water temperature? If so, I know what to look for.
Oh, and is the motor in the 90% Guardian mode? if so, can I erase the fault codes to get it back to 100%? Thanks much!! Jeff Sounds like same thing that happened to me,had a seawater impeller fail and shortly after that the 2 alarm trouble started.. I`ll double check that sensor on the pump...did u replace yours and how much was it? tnx |
Originally Posted by bcolmsted
Hp500
Thats definitly the problem, as soon as I disconnected that sensor the 2 alarms started up...The connector looked fine ,however...I`ll have to wait and see if alarms come back before I buy a new sensor.
bco |
| All times are GMT -5. The time now is 10:16 PM. |
