Need wide -tip flathead
The magnetic vent and drain plugs for XR drives are wider than any screwdriver I can find. Any suggestions where to find one and what the exact size width is? Thank you.
Re: Need wide -tip flathead
snap on part # SGD8 works fine on my 06 XR
What are you some sort of Toolman or somethin'? :D
Sounds like a Matco # :eek: :D |
If you're in a hurry, Sears has drag link sockets- essentially a big flat-blade bit.
the snap on says 3/8 and I think I have one but I'll measure the vent screw.
I need the same size as width of screw slot. Sears is my next stop. |
| All times are GMT -5. The time now is 08:11 AM. |
