-   -   water pump puley locked up (https://www.offshoreonly.com/forums/general-q/139584-water-pump-puley-locked-up.html)
gsmith9898 09-04-2006 04:44 PM
Yesterday after running hard for awhile I turned off my motor for a couple of minutes while talking to someone. When I started my engine the pulley was not turning on the sea pump. The belt was tight and the pulley was locked up. I turned it off Nad on three times and than it started turning and worked fine after that. Any ideas?
TxFountain 09-04-2006 05:55 PM
Re: water pump puley locked up
Your rubber impeller is coming apart.
gsmith9898 09-04-2006 06:48 PM
I just changed the impeller a few months back. It has probably 10 hours on it.
Pwrbt33 09-04-2006 07:06 PM
Sometimes when shutting a motor off it will spin backwards for a second, call it dieseling or run on if you will. This will cause the impeller to flip the vanes backwards. It will do exactly what you are saying. It has happened to me more than once. Just had to reach down and turn it by hand and then it was fine. I have also had this happen on brand new ones so I knew I didn't lock a pump up.
John S. :D
michigan troll 09-05-2006 06:19 AM
The pump bearings are probably shot. If you have a mechanical fuel pump your water pump has a fill and check spot on the water pump body. If you have an electrical fuel pump you only have what grease the assembler put on the water pump bearings. Not much.
gsmith9898 09-05-2006 07:48 AM
its the 525efi motor. Has to be electric fuel pump. I did not see a place to grease the bearings.
