Engine Internals/Components
I'm planning on using the following for my 540, M-3 Procharger Build:
Merlin lll block (not sure if I am going 9.8 or 10.2 deck yet) AFR 315 Heads CNC Ported, Assembled Callies or Lunati Crank Oliver Rods JE Blower Pistons 9:1 or so T&D Shaft Rockers Billet cam from Bob Madera Morel Lifters Hoping to run 800+ at 3 PSI of boost and almost 900 HP at 9 PSI of boost. Konrad ACE Drive and CMI Headers of course! Im interested in input and proven results from similar builds. Any issues with the above components? |
Re: Engine Internals/Components
CR seems a little high, even the 1075 merc runs only 8.0:1
Jesel > T&D
he's absolutely right about the cr... 9 to 1 and the next post we see from you will start.. " gee i rolled into the throttles and all of a sudden bthe boat was full of smoke and all the pistons were in the bilge... ..."
I'm running 8:1 right now and have been told it's a little low. I was told that 8.8:1 is a little better. Anyone else have proven results with thsi set up and what compression are you running?
I don't need to have any issues with the $$ I'm putting into this project! |
Carb or EFI?
Efi
if you are running a blower then my opinion is anying above 8.5 is asking for trouble unless you are REALLY on your game for fuel and all other monitoring parameters...and you BETTER have the best knock sensor retard system ever made.
The engine will be dyno'd with O2 sensors and EGTs.
Once in the boat, it will be rechecked and recalibrated with O2 sensors. |
| All times are GMT -5. The time now is 09:24 PM. |
