-   -   bmax upper and bravo lower ? (https://www.offshoreonly.com/forums/general-q/140359-bmax-upper-bravo-lower.html)
docmanrich37 09-13-2006 08:59 AM
How are you using bmax uppers when the lower bravo has a smaller shaft and coupler.
I'm looking at just trying this weekend a bravo lower on my bmaxs.Thanks Rich
Back4More 09-13-2006 10:37 AM
Re: bmax upper and bravo lower ?
The lower needs the big shaft....Did you get the new lowers from Dean yet?
zt260 09-13-2006 10:54 AM
You can put the larger bmax lower vertical shaft in and run any bravo lower with the bmax upper. There is no other way to do it according to Dean.
docmanrich37 09-13-2006 11:24 AM
I guess i'll wait till next week when Dean sends me my new lowers.They're a differant style all together and they aren't a 2" shortie.
Strip Poker 388 09-16-2006 03:07 PM
I dont think the cooling passages will line up also
WILDTHING TAZ 09-16-2006 07:42 PM
You Must Use The B-max Vertical Shaft. Because Of The Coupler Size. And The Water Passage In The Bravo Lower Must Be Plugged. Then The Bravo Lower Will Work. Ron Bender 216-390-1330
