-   -   no oil psi no knock (https://www.offshoreonly.com/forums/general-q/140825-no-oil-psi-no-knock.html)
osen007 09-18-2006 06:45 PM
no oil psi no knock
6-7 psi oil pressure no knocking yet!!!! at WOT 20-25 psi.. what do you think it could be?
Lofty 09-18-2006 06:58 PM
Re: no oil psi no knock
Could be a bad sending unit. If the diaphragm leaks it will give low readings. Try running a mechanical guage. We test them by running a mechanical guage up to the back seat, have someone give you the readings. If you wait to hear knocking it's too late.
jeffswav 09-18-2006 07:36 PM
I keep a mechanical gauge in my tool box. Just get a cheep one from the auto parts store. If your mains are going out you do not want to keep running it.
happy hours 09-18-2006 07:43 PM
Ditto, I got scared a couple years back with no pressure and the sender was bad......I think the spring that holds back diaphragm breaks/weakens.
osen007 09-19-2006 08:45 AM
that is on a mechanical gauge
1BIGJIM 09-19-2006 09:32 AM
Pickup tube? I would not be running the engine until I found out the problem.
gsmith9898 09-19-2006 09:38 AM
change the filter first.
Raylar 09-19-2006 12:18 PM
We need some more infor here. What motor?, is it new or newly rebuilt? Have you made any changes to filters or coolers? How was oil pressure before and when did this appear? Just not enough info here to give an intelligent opinion here.
Ray @ Raylar
nocigarette 09-19-2006 05:21 PM
I Agree More Info......mech Gauge, Low Oil Pressure. I Would Be Unbolting It And Pulling It......
happy hours 09-19-2006 06:49 PM
Could it be a bad mechanical gauge? Admittedly , I might be well wishing here but is this the second guage to read these pressures? Maybe the gauge is bad.....sure would suk to pull it and disassemble to find that out. I agree with everyone else though if the pressure is accurate pull it and save what you can before it all worst.
